查看: 1608|回复: 6
[提问] ( command "-image"....)稳定执行的问题
发表于 2014-7-24 22:38:53 | 显示全部楼层 |阅读模式
各位大侠,请求该命令帮忙解决:
(command "-image" "attach" word axi_point 1 0 ),执行后出现如图报警。
其中的word 与插入点由以下程序生成:
(setq        fname (getfiled        "Pls input file name"
                        "pot"
                        2              )
  (setq fim (open fname "r"))
  (setq strname (read-line fim))
  (close fim)
  (setq imd (strlen strname))
  (setq word (read strname))
插入点是自己前面定义进去的变动点word与axi_point也可以写成""  "", 即变成(command "-image" "attach" "" "" 1 0 ),但是也没有用处,还是有此报警
加上后续的循环判断,用附件文件读,加上29副jpg图片(其实任意几幅也可以)
 楼主| 发表于 2014-7-25 19:38:48 | 显示全部楼层
谁能够帮助解答?
(defun c:inimage (/                fname              fim
                  strname        imd              word
                  chklay        image              image_angle
                  die_angle        scale_dim     die_center
                  die_center_asist              tape_center_asist
                  center_dim chksty
  (setvar "CMDECHO" 0)
   (setq fname (getfiled "Pls input file's name" "" "pot" 2))
  (while (/= imd 0)
    (setq word (read strname))                ;该行字符赋予word
    (command "-image" "attach" word "" "" "" "")
     (setq strname (read-line fim))        ;读一行
    (setq imd (strlen strname))                ;返回字符串的个数
  (setvar "CMDECHO" 1)
即使是这个不加字符串word与插入点的运行也不稳定。
发表于 2014-7-26 08:22:54 | 显示全部楼层
  1. (defun c:inimage (/ fname fim strname)
  2.   (setvar "CMDECHO" 0)
  3.    (setq fname (getfiled "Pls input file's name" "" "pot" 2))
  4.   (setq fim (open fname "r"))
  5.   (while (/= (setq strname (read-line fim)) "")
  6.     (command "-image" "attach" strname "" "" "" "")
  7.   )
  8.   (close fim)
  9.   (setvar "CMDECHO" 1)
  10. )
 楼主| 发表于 2014-7-26 12:53:38 | 显示全部楼层
谢谢,我会试验下。
 楼主| 发表于 2014-7-26 13:06:16 | 显示全部楼层
经过试验,还是不行,程序会出现没有响应报警
发表于 2014-8-4 18:27:38 | 显示全部楼层
2008版以后的CAD,"-image" 这个命令经常出现卡死现象。
发表于 2017-12-11 13:51:38 | 显示全部楼层
2007以后的版本都有这个问题,
我是遇到用CTRL+v直接粘贴图片进CAD卡死问题,
后面把这个acad2007doc.lsp,里imagefile子程序里
用VLA-ADDRASTER 替代 "-image"命令才可以。
;00修复2007以后CAD不能CTRL+v粘贴图片问题
(DEFUN imagefile (filename) ;/ filedia-save cmdecho-save)
   (VL-LOAD-COM)
   (SETVAR "cmdecho" 0)
   (SETQ mspace        (VLA-GET-MODELSPACE
                   (VLA-GET-ACTIVEDOCUMENT
                      (VLAX-GET-ACAD-OBJECT)
                   ) ;_ 结束vla-get-activedocument
                ) ;_ 结束vla-get-modelspace
   ) ;_ 结束setq
   (SETQ po1_mga (GETPOINT "\n图像插入点: "))
   (SETQ po_mga (VLAX-3D-POINT po1_mga))
   (SETQ obj_mga (VLA-ADDRASTER mspace (FINDFILE filename) po_mga 100 0))
   (SETQ ename_mga (VLAX-VLA-OBJECT->ENAME obj_mga))
   (VLA-GETBOUNDINGBOX obj_mga 'll 'ur)
   (SETQ po2_mga (CADR (MAPCAR 'VLAX-SAFEARRAY->LIST (LIST ll ur))))
   (SETQ po3_mga (LIST (CAR po1_mga) (CADR po2_mga)))
   (VL-CMDF "SCALE" ename_mga "" po1_mga "r" po1_mga po3_mga pause)
   (PRIN1)
) ;d
GMT+8, 2025-11-15 14:23 , Processed in 0.273018 second(s), 27 queries , Gzip On.
