 - ;;画线标高绘制主程序
- ;;code by edta 2014-7-28 @mjtd.com
- ;;命令bg2
- (defun c:bg2(/ p1 p2 sk_level_s ang p3)
- (vl-load-com)
- (vla-StartUndoMark(vla-get-ActiveDocument (vlax-get-acad-object)))
- (setq *error*_Old *error*) ;保存出错处理函数
- (setq *error* *error*_New)
- (or sk_scale (setq sk_scale(cond((getint (strcat "\n输入标高比例<100>: ")))(100))))
- (or sk_level (setq sk_level 0.000))
- (setq bak_dimzin(getvar 'dimzin))
- (setvar 'dimzin 0)
- (if(and(setq sk_level(cond((getreal (strcat "\n输入标高值<"(rtos sk_level 2 3)">:")))(sk_level)))
- (list t (initget "s _s"))
- (setq p1(getpoint (strcat "\n指定第一点/(S)标高比例<" (itoa sk_scale) ">:")))
- (if (= p1 "s")
- (progn
- (setq sk_scale(cond((getint (strcat "\n输入标高比例<"(itoa sk_scale)">: ")))(sk_scale)))
- (setq p1(getpoint (strcat "\n指定第一点,当前标高比例<"(itoa sk_scale)">: "))))
- t
- (setq p2(getpoint p1 "\n指定第二点:"))
- (progn
- (if (equal sk_level 0.000)
- (setq sk_level_s "%%P0.000")
- (setq sk_level_s (rtos sk_level 2 3))
- (setq ang(angle p1 p2))
- (if (and (>= ang (* pi 0.5))(<= ang (* pi 1.5)))
- (setq p3 p1 p1 p2 p2 p3))
- (sk_mk_level p1 p2 sk_level_s sk_scale)
- (entmake (list '(0 . "LINE") (cons 10 p1) (cons 11 p2)))
- (and bak_dimzin(setvar 'dimzin bak_dimzin))
- (and *error*_Old(setq *error* *error*_Old))
- (vla-EndUndoMark(vla-get-ActiveDocument (vlax-get-acad-object)))
- (princ)
- ;;标高生成函数
- (defun sk_mk_level(p1 p2 sk_level sk_scale / ang lst mpt mpt1 p4 pt pt1 pt3 pt4 pt5 pt6)
- (setq mpt(mapcar '(lambda(x y)(* 0.5 (+ x y))) p1 p2)
- ang(angle p1 p2)
- mpt1(polar mpt (+ ang (* 0.5 pi)) (* 3 sk_scale))
- pt1(polar mpt1 ang (* 3 sk_scale))
- pt3(polar mpt1 ang (* -3 sk_scale))
- pt4(polar mpt1 ang (* 15 sk_scale))
- pt5(polar mpt1 ang (* 9 sk_scale))
- lst (list pt1 mpt pt3 pt4)
- (entmake (append
- (list '(0 . "LWPOLYLINE")
- '(100 . "AcDbEntity")
- '(100 . "AcDbPolyline")
- (cons 90 (length lst)))
- (mapcar '(lambda (pt)(cons 10 pt)) lst ))
- (entmake (list '(0 . "TEXT")
- (cons 1 sk_level)
- (cons 73 1)
- (cons 72 1)
- (cons 10 pt4)
- (cons 11 pt5)
- (cons 40 (* sk_scale 2.5))
- (cons 50 ang))
- ;;出错处理函数
- (defun *error*_New (msg)
- (if (wcmatch (strcase msg t) "*break,*cancel*,*exit*,*取消*")
- (if (= (getvar "LOCALE") "CHS")
- (princ "\n用户按了<Esc>强制退出")
- (princ "\nYou cancelled The operation!")
- (princ (strcat "\n" msg))
- (princ)
- (vl-load-com)
- (prompt "\n画线标高 命令bg2")
- (princ)
