查看: 1165|回复: 2
[讨论] 斜直线与圆弧坐标点的确定
发表于 2014-8-13 20:17:56 | 显示全部楼层 |阅读模式
见附图斜直线与圆弧坐标点的确定
请高手指点指点
cad是2013版的
发表于 2014-8-14 15:24:46 | 显示全部楼层
  1. ;;code by qjchen
  2. (defun q:geo:2line:ang2(p1 p2 p3 p4)
  3.   ((lambda(x) (atan (sqrt (abs (- 1.0 (* x x)))) x))
  4.      (/ (apply '+ (mapcar '* (mapcar '- p2 p1) (mapcar '- p4 p3))) (distance p1 p2) (distance p3 p4))
  5.   )
  6. )
  7. (defun c:tt(/ ng0 ang1 ang3 ang4 cen ds1 ds2 ipt mpt p0 p1 p1a p2 p3 p4 p5 p5a r)
  8.   (setq p1 '(-16.25 0)
  9.         p0 '(0 0)
  10.         p5 '(0 7)
  11.         ang0 (* 5.71059314 (/  pi 180.0) );角度值转弧度值
  12.         r 3.5
  13.         )
  14.   (setq p5a(polar p5 ang0 1.0) ;求p5->p4斜线上一点p5a
  15.         p1a(polar p1 (* pi 0.5) 1.0) ;求p1->p2直线上一点p1a
  16.         ipt(inters p1 p1a p5 p5a nil);求p5->p5a p1->p1a直线交点ipt
  17.         ang1 (* (q:geo:2line:ang2 ipt p1 ipt p5) 0.5);求p5->p5a p1->p1a直线夹角值ang1
  18.         ds1 (/ (* r (cos ang1)) (sin ang1));求ipt->p4长度(圆弧与斜线是垂直的,已知角度\对边,求邻边长)
  19.         ds2 (/ r (sin ang1));求ipt->cen长度(圆弧与斜线是垂直的,已知角度\对边,求斜边边长)
  20.         )
  21.   (setq p2(polar ipt (angle ipt p1) ds1) ;求得p2点
  22.         p4(polar ipt (angle ipt p5) ds1) ;求得p4点
  23.         )
  24.   (setq mpt(mapcar '(lambda(x y)(* 0.5 (+ x y))) p2 p4) ;求得p2->p4的中点
  25.         ang3(angle ipt mpt);求ipt->mpt角度
  26.         ang4(angle mpt ipt);求mpt->ipt角度
  27.         cen(polar ipt  ang3 ds2);求圆心cen点
  28.         p3(polar cen ang4 r);求p3点
  29.         )
  30.   ;(command "line" "non" p2 "non" p1 "non" p0 "non" p5 "non" p4 "")
  31.   ;(command "arc" "non" p2 "non" p3 "non" p4 "")
  32.   (command "pline" "non" p0 "non" p1 "non" p2 "a" "non" p4 "l" "non" p5 "c")
  33.   )
 楼主| 发表于 2014-8-17 21:10:07 | 显示全部楼层
谢谢
看看学习一下
GMT+8, 2025-5-24 05:49 , Processed in 0.178316 second(s), 26 queries , Gzip On.
