查看: 971|回复: 2
[已解答] 求救!!请大神指点!~~~~
发表于 2014-8-23 08:29:13 | 显示全部楼层 |阅读模式
我编的画多段线的简单语句,为什么画出来的图形有时候是不一样的?
(defun c:ddf(/ pt01)
(setq pt01(getpoint "选取01剖面的中心点:"))
(command "pline" pt01
"@11.5,2.164"
"@-2,-0.465"
"@-1.5,-1.117"
"@-3.8,-0.083"
"@-0.2,-0.343"
"@-7,-0.107"
"@-1.5,0.193"
"@-1,0.313"
"@-1.5,0.087"
"@-7,0.149"
发表于 2014-8-23 10:24:41 | 显示全部楼层
把各种捕捉关掉
 楼主| 发表于 2014-8-23 10:38:32 | 显示全部楼层
哦,非常感谢!!输入数据的还能受到捕捉的影响,没有想到!!
GMT+8, 2025-5-24 06:28 , Processed in 0.169545 second(s), 26 queries , Gzip On.
