查看: 916|回复: 1
[提问] 出错了,求高手帮忙~~
发表于 2014-8-29 14:30:45 | 显示全部楼层 |阅读模式
一运行就会出错,求帮忙分析下
  1. (command "OPENDCL")
  2. (vl-load-com)
  3. (defun mktxt (str pt)
  4. (entmake (list '(0 . "TEXT") (cons 1 str) (cons 10 pt) (cons 40 5)))
  5. )
  6. (defun c:TEST_Form1_OnClose (UpperLeftX UpperLeftY /)
  7.   (dcl_Form_Close TEST_Form1)
  8. )
  9. (defun c:TEST_Form1_OnInitialize (/)
  10.   (PRINC "\n成功!")
  11. )
  12. (defun c:TEST_Form1_TextButton1_OnClicked ( / )
  13.   (setq TXT1(dcl_Control_GetText TEST_Form1_TextBox1)
  14.         i (atoi(dcl_Control_GetText TEST_Form1_TextBox2))
  15.         TXT2(dcl_Control_GetText TEST_Form1_TextBox3)
  16.           )
  17.   (while (setq p1 (getpoint "\n 标注点:"))
  18.       (mktxt (strcat TXT1 (itoa i) TXT2) p1)
  19.       (setq i (1+ i))
  20.   )
  21. )
  22. (defun C:TT ( / )
  23. (setq string (apply 'strcat
  24. '("YWt6A/obAABn0iQGBuKTJiU1Ki9qgDg5o+cKzwT2XsRmN9ezJt9tbArbLK2y7jZuY8tSUa8zjTuW"
  25. "19ZgBNf5hHcj33WKJnr7esOKqHF2tAT1lhgVE+OnmQIz4DhzYeJnsEeFpRXRA4gnFQOhkk2NOQHz"
  26. "PPA7Rc97s9a7B6rfYw8KdRS6UGLqDWob1u8ow/ByWQQ9fqCafw3KX/jcs1ZpuUgPofJ2HFY7WyR7"
  27. "FRVtVJpl6SgyhFSuX9MoCrTGxuKrZO8NuiCT7Di5GPI3MTJorlDdXZytWOAvx/GwZukI2ZPV7sDW"
  28. "ygp76whAY6kYGaJWQ3gNCywj1oNS/XdfVf+66s1lA0b7YOe7gjqQxl/aMJhonw1AwkZQ/zX62nsQ"
  29. "4Gh3GlEINl6FDiQoHXgX4C+8kXaJhY6s95HNKfBQ4u/dK5Cm+z/DnXPkj3Sfou5hAVmFfp/pVjK6"
  30. "EkIG2H8fBkAYtnuHw5quQj3wsSCWkpP0zT03AUvmWbAQuUFcguaOPbxBnuERy0Gzq0MRUek/wZjr"
  31. "sXwtkhgEU/lT5hITFjF3abKiOHeO/noCRbC0h/La3Sn12b5pzCsBMSQUASlKIyygWRoyRTJw25dg"
  32. "25twn8X6EW2QMLi2QM9HP8ZZZ/euabMfYafxbcAyjfFaXUv4AcePSFnhtoFdjALG9oJBxYsmBfRM"
  33. "smz08QEy4zUawJwiIZzMrkwCpqLZzAM+RuG09rXGqUkZP9NaBvtiuVofo4wj/+MMQJRViZuUCeOY"
  34. "I5ySK/SVY8DYhv69pWoB3twjPYCFY1AoIjOK1l8iNQZhH25D50oVlwf0g5XPWjRqechM9/JdP+Ei"
  35. "3f/Xoz7J9W6I1rFJ06LONeXLBTTdIk9NFfzMzoCNfOa4MnJU3fvtUlUYXk3qZ7JyGXsGlJxM3J1V"
  36. "V3DgTCDyahvC4JwC75yuOMb3zvl45BJRcyBWUN/MUluydKo/BmNDsQ28SRfC+Qg9FBFYhTTB2hLt"
  37. "0/lXDUAhu1cuiyZb56TSBD9Ul+98VUtgV6bTxu3gH9Ssbt1m2F9zxOCK2t9CXXNnF0Z6wUpyHhjb"
  38. "32D/rG70GPpfcx+uQzUEvM5PXXJnH8Z+wU4qHRj7P2FSFrEuVBH+ZxfmuuBfly+4rO4lHYEQrMRx"
  39. "AOueQVS8OlVxkxVqrSUaE334gO78fNpZc4JcYVpzglxBIxHXgSVkQizOflfWYcqDGdQE1gh3TTVl"
  40. "xSBxE+RrMetY7Qe1gFkkehHd2Tj1DoGrn71ZReTwGtZPg6o2x4Pj/mQFTsXXbz9EqnagNjCPaR0g"
  41. "HZhpfYH/aFdJAW2uHEAYSVPUuNHBfwoGQp4=")
  42. ))
  43. (dcl_project_import string nil nil)
  44. (dcl_form_show TEST_form1)
  45. )
 楼主| 发表于 2014-8-29 14:35:40 | 显示全部楼层
                        (setq i (1+ i))
这一串代码测试是可以运行的,可为什么点按钮就不能运行了呢?求指点~~~~
GMT+8, 2025-5-24 03:56 , Processed in 0.167357 second(s), 27 queries , Gzip On.
