查看: 1627|回复: 5
[提问] 谁帮忙检查下代码错在什么地方???
发表于 2014-9-1 18:19:00 | 显示全部楼层 |阅读模式
(defun C:door ()
(setq pt1 (getpoint))
(setq pt2 (getcorner pt1))
(setq rad (angle pt1 pt2))
(if (= rad 1.5708)
       (setq pt3 (polar pt1 pi 800))
       (setq pt4 (polar pt2 pi 800))
       (setq pt5 (polar pt1 pi 400))
       (setq pt6 (polar pt2 pi 400))
       (command "line" pt1 pt2 "")
       (setq b1 (entlast))
       (command "line" pt3 pt4 "")
       (setq b2 (entlast))
       (command "trim" b1 b2 "" pt5 pt6 "")
(if (= rad 4.71239)
       (command "line" pt1 pt2)
       (setq b1 (entlast))
       (command "line" pt3 pt4)
       (setq b2 (entlast))
(if (= rad 0)
       (setq pt3 (polar pt1 (* pi 0.5) 800))
       (setq pt4 (polar pt2 (* pi 0.5) 800))
       (setq pt5 (polar pt1 (* pi 0.5) 400))
       (setq pt6 (polar pt2 (* pi 0.5) 400))
       (setq b1 (entlast))
       (setq b2 (entlast))
(if (= rad 3.14159)
       (setq b1 (entlast))
       (setq b2 (entlast))
       (command b1 b2 "" pt5 pt6 "")
  (prin1)
发表于 2014-9-1 19:45:15 | 显示全部楼层
关掉捕捉试试。
发表于 2014-9-1 20:05:45 | 显示全部楼层
  1. (defun C:door ()
  2.   (setvar "CMDECHO" 0)
  3.   (setq oldos (getvar "OSMODE"))
  4.   (setq pt1 (getpoint))
  5.   (setq pt2 (getpoint pt1))
  6.   (setq rad (+ (/ pi 2) (angle pt1 pt2)))
  7.   (setq pt3 (polar pt1 rad 800))
  8.   (setq pt4 (polar pt2 rad 800))
  9.   (setq pt5 (polar pt1 rad 400))
  10.   (setq pt6 (polar pt2 rad 400))
  11.   (setvar "OSMODE" 0)
  12.   (command "line" pt1 pt2 "")
  13.   (setq b1 (entlast))
  14.   (command "line" pt3 pt4 "")
  15.   (setq b2 (entlast))
  16.   (command "trim" b1 b2 "" pt5 pt6 "")
  17.   (setvar "OSMODE" oldos)
  18.   (setvar "CMDECHO" 1)
  19.   (prin1)
  20. )
 楼主| 发表于 2014-9-1 20:24:46 | 显示全部楼层
ZZXXQQ 发表于 2014-9-1 20:05
好代码~~~~
 楼主| 发表于 2014-9-1 20:41:00 | 显示全部楼层
问一下这个 判断为什么判断不出来呢????
发表于 2014-9-1 20:47:09 | 显示全部楼层
实数的比较有误差,要用equal
GMT+8, 2025-11-26 07:55 , Processed in 0.184230 second(s), 29 queries , Gzip On.
