查看: 1073|回复: 2
[已解答] 怎么把图层信息添加到控件里面,谢谢
发表于 2014-9-18 17:58:37 | 显示全部楼层 |阅读模式
怎么把图层信息添加到控件里面,谢谢
发表于 2014-9-19 08:35:39 | 显示全部楼层
  1. (defun c:tt ()
  2. (setvar "cmdecho" 0)
  3. (setq lalst (list) lay nil)
  4. (while (setq lay (tblnext "LAYER" (not lay)))
  5.   (setq lalst (cons (cdr(assoc 2 lay)) lalst))
  6. )
  7. (if (> (setq dcl_id (load_dialog "tucheng")) 0) (progn
  8.   (if (new_dialog "tucheng" dcl_id) (progn
  9.   (start_list "n1")
  10.   (mapcar 'add_list lalst)
  11.   (end_list)
  12.   (action_tile "accept" "(ok_tucheng)(done_dialog 1)")
  13.   (setq dd (start_dialog))                                ;调用对话框子程序
  14.   )
  15.    (princ "\n无法显示对话框!")
  16.   )
  17.   (unload_dialog dcl_id)
  18. )
  19.   (princ "\n无法加载对话框!")
  20. )
  21. (if (= dd 1) (princ lnm))
  22. (prin1)
  23. )
  24. (defun ok_tucheng ()
  25.   (setq lnm (nth (atoi (get_tile "n1")) lalst))        ;取得对话框内的ww值
  26. )
 楼主| 发表于 2014-9-19 10:01:54 | 显示全部楼层
非常谢谢
GMT+8, 2024-11-16 19:01 , Processed in 0.177281 second(s), 29 queries , Gzip On.
