查看: 2304|回复: 3
[已解答] 求取面积
发表于 2014-9-19 19:45:34 | 显示全部楼层 |阅读模式
lisp如何通过选取内部点求取任意封闭区域的面积,比如区域为相交的直线或圆弧?就像图案填充自动查找边界,求取由边界包围部分的面积?
发表于 2014-9-19 20:21:14 | 显示全部楼层
用Bpoly
第二行補字
发表于 2014-9-20 02:35:10 | 显示全部楼层
(defun c:dmj()
  (setvar "cmdecho" 0)
(setq cth (rtos (getvar "textsize")))
    (setq TextHeight (getdist (strcat "\n输入标注文字高度 < " cth " > : ")))
    (if (= TextHeight nil)(setq TextHeight cth))
(command "style" "tukou" "黑体" "0" "" "0" "" "")
(command "layer" "M" "面积单注" "C" "1" "" "LT" "CONTINUOUS" "" "");设置一个标注图层
  (defun maketext (txt pt)                ; 生成文字子函数
    (entmake (list '(0 . "TEXT")
                   (cons 62 3)
                   (cons 10 pt)
                   (cons 40 TextHeight)
                   (cons 1 txt)
                   '(41 . 0.6)
  (setq pt (getpoint "\n选取点:"))
  (while pt
    (setvar "cecolor" "1")
    (command "bpoly" pt "")
    (setq en (entlast))
    (if (/= en nil)
(command "area" "o" en)
(setq aa (getvar "area"))
(redraw en 3)
(setq bb (strcat "S=" (rtos aa 2 2 )"㎡"))
(setq pt1 (getpoint "请指定面积书写位置:"))
(command "_text" pt1 TextHeight "" bb 0)
    (entdel en)
    (setvar "cecolor" "bylayer")
  (prin1)
 楼主| 发表于 2014-9-20 10:25:11 | 显示全部楼层
非常感谢lsjj 和香田里浪人的指导。
GMT+8, 2025-10-31 13:11 , Processed in 0.176179 second(s), 26 queries , Gzip On.
