请教各位大侠,有很多数据,动态DCL页面一列显示不开,希望多列显示,图片为下面程序运行结果:boxed_column没有分成两列而还是两行?前一个程序为转为LISP前的DCL,请哪位能否提供个类似例子学习下,谢谢!
 - choice : dialog {label = "test" ;
- :boxed_row {
- :row { //:boxed_column//:boxed_row
- :edit_box { label="【位】";width=6;key="editpartname01";}
- spacer;
- ok_cancel ;
 - (defun c:test (/ CAVLST CAVLST1 EDITPARTLST01 FNAME FN DCL_ID RESULT)
- (setq Cavlst '( "a0" "a1" "a2" "a3""a4" "a5" "a6"))
- (setq Cavlst1 '( ("a0" "a1" "a2" "a3")("a4" "a5" "a6" )));_将Cavlst分成两个表
- (setq editpartlst01 '(("a1c1"); "a1c2" "a1c3")
- ("a2c1" "a2c2"); "a2c3")
- ("a3c1" "a3c2" "a3c3")
- ;__________________________________________________________________________
- (setq fname (vl-filename-mktemp nil nil ".dcl"))
- (setq fn (open fname "w"))
- (write-line "choice : dialog {label = \"test\" ;" fn)
- (foreach Cavlst2 Cavlst1 (if Cavlst2
- (progn (write-line " :boxed_column { " fn)
- (foreach n Cavlst2 (if n (progn
- (write-line " :row{ //:boxed_column//:boxed_row" fn)
- (write-line (strcat " :edit_box { label=" (addw (strcat n "【位】"))";width=6;key="(addw (strcat "editpartname01" n) ) ";}" )fn)
- (write-line " }" fn)
- );_progn
- );_if
- );_内层foreach
- );_progn
- );_if
- );_外层foreach
- (write-line " ok_cancel ;" fn)
- (close fn)
- (setq fn (open fname "r"))
- (setq dcl_id (load_dialog fname))
- ;____________________________________________________________________________
- (if (not (new_dialog "choice" dcl_id))
- (exit)
- (foreach n Cavlst (if n
- (set_tile (strcat "editpartname01" n) (nth 0 (nth 0 editpartlst01)) )
- (action_tile "accept" "(done_dialog 1)")
- (action_tile "cancel" "(done_dialog 0)")
- (setq result (start_dialog))
- (unload_dialog dcl_id)
- (if (= 1 result)
- (alert
- (strcat "NIHAO! ")
- ;; do your mojo here
- (princ)
- (princ "\n *****c: test ()** ")
- (defun addw(a / );_将\加到字符两侧
- (strcat "\"" a "\"")
