引用http://bbs.mjtd.com/thread-6521-1-1.html 龙龙仔 的源码
跟据个人需求,改了一下输入顺序,加了个循环!但是有个问题解决不了,想请教一下! - ;;;多段线单边偏移
- (defun l_offset (/ ce os ENT ENT1 ENT2 DIST PNT)
- (defun SEGMENTPTS (ENT / PNT VOBJ PARAM1 PARAM2 P1 P2 SEGPTS)
- (and
- (setq VOBJ (vlax-ename->vla-object (car ENT)))
- (setq PNT (trans (cadr ENT) 1 0))
- (setq PNT (vlax-curve-getclosestpointto VOBJ PNT))
- (setq PARAM1 (vlax-curve-getparamatpoint VOBJ PNT))
- (setq PARAM1 (fix PARAM1))
- (setq PARAM2 (1+ PARAM1))
- (if (equal PARAM1 (vlax-curve-getstartparam VOBJ) 1e-10)
- (setq P1 (vlax-curve-getstartpoint VOBJ))
- (setq P1 (vlax-curve-getpointatparam VOBJ PARAM1))
- (if (equal PARAM2 (vlax-curve-getendparam VOBJ) 1e-10)
- (setq P2 (vlax-curve-getendpoint VOBJ))
- (setq P2 (vlax-curve-getpointatparam VOBJ PARAM2))
- P1
- P2
- (setq BULGE (vla-getbulge VOBJ PARAM1))
- (setq SEGPTS (list P1 P2 BULGE))
- SEGPTS
- (defun CALCBULGE (ENT / ARCRAD CENDIR HLFANG)
- (setq VX1 (nth 0 ENT)
- VX2 (nth 1 ENT)
- BLG (nth 2 ENT)
- (setq HLFANG (* 2 (atan BLG))
- CENDIR ((if (< BLG 0)
- (- (angle VX1 VX2) HLFANG)
- (/ pi 2)
- ARCRAD (abs (/ (/ (distance VX1 VX2) 2.0) (sin HLFANG)))
- (list
- (polar VX1 CENDIR ARCRAD)
- ARCRAD
- (* (abs HLFANG) 2.0)
- (setq ce (getvar "cmdecho"))
- (setvar "cmdecho" 0)
- (command "_.undo" "_group")
- (setq os (getvar "osmode"))
- (setvar "osmode" 0)
- (setq DIST (getreal "\n输入偏移距离<3>:"))
- (if (= dist nil)
- (setq dist 3)
- (setq b 1)
- (while (<= b 100)
- (prompt "\n拾取POLYLINE要偏移的段: ")
- (setq ENT (ssget ":S" '((0 . "*POLYLINE"))))
- (if (not (null ENT))(progn
- (setq ENT (list (ssname ENT 0)
- (osnap (cadr (nth 3 (car (ssnamex ENT 0)))) "nea")
- (setq PNT (getpoint "\n拾取方向:"))
- (setq ENT1 (SEGMENTPTS ENT))
- (if (/= (nth 2 ENT1) 0)
- (setq ENT (CALCBULGE ENT1))
- (if (> (nth 2 ENT1) 0)
- (command "_.arc" "c" (nth 0 ENT) (nth 0 ENT1) (nth 1 ENT1))
- (command "_.arc" "c" (nth 0 ENT) (nth 1 ENT1) (nth 0 ENT1))
- (command "_.line" (nth 0 ENT1) (nth 1 ENT1) "")
- (setq ENT2 (entlast))
- (command "_.Offset" DIST ENT2 PNT "")
- (entdel ENT2)
- (setq b (1+ b)))
- (setq b 101)))
- (setvar "osmode" os)
- (command "_.undo" "_end")
- (setvar "cmdecho" ce)
- (princ)
- (defun c:of ()
- (l_offset))
跟据个人需求想简化命令,该怎么修改主程式!还想加个判断,先单线的复线都可运行! - (defun c:oo3()
- (command "l_offset" "1")
- (defun c:oo2()
- (command "l_offset" "2")
- (defun c:oo3()
- (command "l_offset" "3")
- (defun c:oo4()
- (command "l_offset" "4")
