查看: 2833|回复: 7
[提问] 请问怎么云线有独立图层,颜色,不打印属性?
发表于 2014-9-24 15:30:24 | 显示全部楼层 |阅读模式
1明经币
这云线LISP也是论坛里找到的,请问怎么再加工,让他有独立图层,颜色,不打印属性?
一点LISP也 不会。求教了。谢谢大家
(defun c:ew(/ x0 y0 x1 y1)
(setvar "cmdecho" 0 )
(SetQ        p0 (GetPoint "\n 第一角点:") x0(car p0) y0(cadr p0)
        p1 (getcorner p0 "\n 另一角点:") x1(car p1) y1(cadr p1)
        dx (abs (- x0 x1))
        dy (abs (- y0 y1))
(Command "rectang" p0 p1)
(if(<= dx dy)
(SetQ al (/ dx 10))
(SetQ al (/ dy 10)))
(Command "revcloud" "a" al al "s" "c" "o" "l" "")
(setvar "cmdecho" 1)
(prinC)
最佳答案
查看完整内容
试试: (defun c:ew(/ x0 y0 x1 y1) (setvar "cmdecho" 0 ) (setq oldlayer (getvar "clayer")) (command "_layer" "n" "云线" "c" "1" "云线" "p" "n" "云线" "") (setvar "clayer" "云线") (SetQ p0 (GetPoint "\n 第一角点:") x0(car p0) y0(cadr p0) p1 (getcorner p0 "\n 另一角点:") x1(car p1) y1(cadr p1) dx (abs (- x0 x1)) dy (abs (- y0 y1)) ) (Command "rectang ...
发表于 2014-9-24 15:30:25 | 显示全部楼层
试试:
         dx (abs (- x0 x1))
         dy (abs (- y0 y1))
(if(<= dx dy)
(SetQ al (/ dx 10))
(setvar "clayer" oldlayer)
(prinC)
 楼主| 发表于 2014-9-24 22:27:22 | 显示全部楼层
谢谢,正是我要的..哈哈
发表于 2015-1-31 13:26:10 | 显示全部楼层
lisp好学                      可也真不好学
发表于 2016-6-25 22:04:09 | 显示全部楼层
smartstar 发表于 2014-9-24 15:30
试试:
怎么加一个动态云线源码?
发表于 2019-6-12 17:01:58 | 显示全部楼层
学习了,谢谢!!!!!
发表于 2019-10-20 11:55:29 | 显示全部楼层
谢谢分享,学习了
发表于 2020-5-12 20:09:57 | 显示全部楼层
大神,能问问问怎么调打印图层跟不打印图层?
GMT+8, 2025-5-18 02:56 , Processed in 0.177681 second(s), 24 queries , Gzip On.
