建议将绝对路径改为相对路径,这样就没必要将程序复制到cad安装目录下! - (setq appdir
- (vl-string-translate
- (strcat (vl-filename-directory (findfile "cooljq.LSP"))
- ;设置hasco运水参数
- (setq hpl (read_cool_file (strcat appdir "Hasco_Z98.TXT")))
- (setq L1 (car hpl))
- (setq cl1 (cadr hpl))
- (setq Papl (read_cool_file (strcat appdir "ParKer.TXT")))
- (setq L2 (car Papl))
- (setq cl2 (cadr Papl))
- (setq Dpl (read_cool_file (strcat appdir "DME_DR.TXT")))
- (setq L3 (car Dpl))
- (setq cl3 (cadr Dpl))
- (setq dcl_id (load_dialog (strcat appdir "cooljq.DCL")))
- (if (not (new_dialog "cooljq" dcl_id))
- (progn (alert "不能装入对话框") (exit))
- (setq tmplst1 '(D1 D2 D3 D4 D5 D6)
- tmplst2 (LIST "dd1" "dd2" "dd3" "dd4" "dd5" "dd6")
- ;;;方便以下简写代码
- (show_sld "img1" (strcat appdir "jiaoquan.sld"))
