查看: 1433|回复: 4
[已解答] 菜鸟的问题:如何实现指定的拉伸距离?
发表于 2014-10-11 12:38:23 | 显示全部楼层 |阅读模式
(defun c:S1 (/ S_distance basicpoint old_ORTHOMODE)
  (setq old_ORTHOMODE (getvar "ORTHOMODE"))
  (setvar "ORTHOMODE" 1)
  (setq S_distance 100)
  (command ".STRETCH" (ssget) "")
  (command (setq basicpoint (getpoint "\n指定基点:")) )
  (command S_distance)
  (setvar "ORTHOMODE" old_ORTHOMODE)
路过的各位伸个手。多谢!
发表于 2014-10-11 21:02:22 | 显示全部楼层
  1. (defun c:S1 (/ S_distance basicpoint old_ORTHOMODE pt)
  2.   (setq old_ORTHOMODE (getvar "ORTHOMODE"))
  3.   (setvar "ORTHOMODE" 1)
  4.   (setq S_distance 100)
  5.   (command ".STRETCH" "C" (ssget) "")
  6.   (setq basicpoint (getpoint "\n指定基点:"))
  7.   (setq pt (getpoint basicpoint "\n指定方向:"))
  8.   (command basicpoint (polar basicpoint (angle basicpoint pt) S_distance))
  9.   (setvar "ORTHOMODE" old_ORTHOMODE)
  10.   (princ)
  11. )
 楼主| 发表于 2014-10-12 11:38:29 | 显示全部楼层
ZZXXQQ 发表于 2014-10-11 21:02
多谢Z版!
但好像 "C" 应该删了。在运行过程中,无法直观看到拉伸方向。能更进一步吗?
 楼主| 发表于 2014-10-13 09:18:52 | 显示全部楼层
Z版,论坛搜到的相关帖子不需要指定方向的。如何修改?
;源地址http://bbs.mjtd.com/forum.php?mod=redirect&goto=findpost&ptid=101864&pid=590781&fromuid=38464
(defun c:SS (/ s_disyd old_ORTHOMODE)
  (command (setq basicpoint (getpoint "\n指定基点:")))
  (if (= nil s_dis_allyd)
    (progn (setq s_dis_allyd (getreal "\n输入拉伸距离:"))
    (command s_dis_allyd)
    (progn (setq
      s_disyd (getreal
         (strcat "\n输入拉伸距离<" (rtos s_dis_allyd) ">")
    (if (= nil s_disyd)
      (setq s_disyd s_dis_allyd)
    (command s_disyd)
    (setq s_dis_allyd s_disyd)
 楼主| 发表于 2014-10-24 15:59:50 | 显示全部楼层
今天又试了,可以用的。多谢Z版!
GMT+8, 2025-7-18 01:46 , Processed in 0.203512 second(s), 28 queries , Gzip On.
