查看: 1787|回复: 8
[源码] 属性与单行文本互转
发表于 2014-10-16 22:28:21 | 显示全部楼层 |阅读模式
新手上路,求大师帮忙优化~~~
  1. ;;; 属性字与单行文字互转
  2. (defun c:tt (/ ss1 n m str)
  3.   (setq ss1 (mj:ss->list (ssget '((0 . "ATTDEF,TEXT"))))
  4.         n 0
  5.         m 0
  6.   )
  7.   (foreach ent ss1
  8.     (cond
  9.       ((= "ATTDEF" (cdr (assoc 0 (entget ent))))
  10.         (setq n (1+ n))
  11.         (att2txt ent)
  12.       )
  13.       ((= "TEXT" (cdr (assoc 0 (entget ent))))
  14.         (setq m (1+ m))
  15.         (txt2att ent)
  16.       )
  17.     )
  18.   )
  19.   (setq str (strcat "转化完成,共转化出<" (rtos n 2 0) ">个文字和<" (rtos m 2 0) ">个属性字"))
  20.   (princ str)
  21.   (princ)
  22. )
  23. ;;; 选择集转图元列表
  24. (defun mj:ss->list (ss1 / is-ename ss)
  25.   (defun is-ename (arg)
  26.     (equal (type arg) 'ename)
  27.   )
  28.   (vl-remove-if-not 'is-ename (mapcar
  29.                                 'cadr
  30.                                 (ssnamex ss1)
  31.                               )
  32.   )
  33. )
  34. ;;; 属性转文本
  35. (defun att2txt (ent / entdxf newdxf malst tem)
  36.   (setq entdxf (entget ent)
  37.         newdxf (list (cons 0 "text") (cons 1 (cdr (assoc 2 entdxf))))
  38.         malst (list 7 8 10 11 39 40 41 50 51 62 71 72 73)
  39.   )
  40.   (foreach mai malst
  41.     (setq tem (assoc mai entdxf))
  42.     (if (/= tem nil)
  43.       (setq newdxf (append
  44.                      newdxf
  45.                      (list (assoc mai entdxf))
  46.                    )
  47.       )
  48.     )
  49.   )
  50.   (entdel ent)
  51.   (entmake newdxf)
  52. )
  53. ;;; 文本转属性
  54. (defun txt2att (ent / entdxf newdxf malst tem)
  55.   (setq entdxf (entget ent)
  56.         newdxf '((0 . "ATTDEF"))
  57.         newdxf (append
  58.                  newdxf
  59.                  (list
  60.                    (cons 1 (cdr (assoc 1 entdxf)))
  61.                    (cons 2 (cdr (assoc 1 entdxf)))
  62.                    (cons 3 (cdr (assoc 1 entdxf))
  63.                    (cons 70 0)
  64.                  )
  65.                )
  66.         malst (list 7 8 10 11 39 40 41 50 51 62 71 72 73)
  67.   )
  68.   (foreach mai malst
  69.     (setq tem (assoc mai entdxf))
  70.     (if (/= tem nil)
  71.       (setq newdxf (append
  72.                      newdxf
  73.                      (list (assoc mai entdxf))
  74.                    )
  75.       )
  76.     )
  77.   )
  78.   (entdel ent)
  79.   (entmake newdxf)
  80. )
发表于 2014-10-16 22:38:08 | 显示全部楼层
不错,感谢分享,不知道怎么优化。
发表于 2014-10-17 00:13:35 | 显示全部楼层
感谢楼主分享程序!
发表于 2014-10-17 06:39:14 | 显示全部楼层
程序无法运行,错误 : no function definition: TXT2ATT
 楼主| 发表于 2014-10-17 10:25:24 | 显示全部楼层
不可能。肯定是你没复制完全~
发表于 2014-10-17 10:54:44 | 显示全部楼层
属性一般是用在属性块中的,单独用是很低效率的用法,如果互转,应该是针对text文本、块中文本及块中属性(attrib)。
发表于 2014-10-26 10:54:00 | 显示全部楼层
语法错误!!!!!!!!!
发表于 2016-1-12 19:26:18 | 显示全部楼层
txt2att函数错误
发表于 2022-3-27 19:10:26 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2024-11-15 01:45 , Processed in 0.200653 second(s), 26 queries , Gzip On.
