查看: 1362|回复: 3
[提问] 【请教】用什么办法实现多段线拟合
发表于 2014-10-23 11:29:12 | 显示全部楼层 |阅读模式
  1. ;;;加入编码
  2. (defun SetData (Obj Data / dxf)
  3.    (setq  dxf (entget obj))
  4.    (setq data (list(list "SOUTH" (cons 1000 data))))
  5.    (foreach x Data
  6.         (regapp (car x))
  7.         (entmod (append dxf (list(cons -3 (list x)))))
  8.    )
  9. )
  10. (defun Hdgxhs (lst n bh h blc / XX xk LAY YS e)
  11.   (setq sw 34.26 BL (/ blc 1000.0))
  12.   (cond ((>= h sw)(setq LAY "DGX" XX "CONTINUOUS"))
  13.   ((< h sw)(setq LAY "DSX" XX "X11"))
  14.   )
  15.   (cond ((= (rem h 5) 0)(setq XK (* 0.3 BL) YS 3))
  16.   ((/= (rem h 5) 0)(setq XK (* 0.15 BL) YS 2))
  17.   )
  18.   (cond ((and(= (rem h 5) 0) (= LAY "DGX"))(setq xDATA "201102"))
  19.         ((and(/= (rem h 5) 0)(= LAY "DGX"))(setq xDATA "201101"))
  20.   ((and(= (rem h 5) 0) (= LAY "DSX"))(setq xDATA "186302"))
  21.         ((and(/= (rem h 5) 0)(= LAY "DSX"))(setq xDATA "186301"))
  22.   )
  23.
  24.   (entmake (append
  25.        (list '(0 . "LWPOLYLINE")
  26.        '(100 . "AcDbEntity")
  27.        '(100 . "AcDbPolyline")
  28.         (cons 8 LAY)
  29.         (cons 62 Ys)
  30.         (cons 90 n)
  31.         (cons 6 xx)
  32.         (cons 43 xk)
  33.         (cons 38 h)
  34.         (cons 70 bh)
  35.        )
  36.       (mapcar '(lambda (pt)(cons 10 pt)) lst ))
  37.   )
  38.   (setq e (entlast))
  39.   (SetData e xDATA)
  40.   (command "_pedit" e "s" "L" "on" "");;;这一句太慢,代替这一句!
  41. )
 楼主| 发表于 2014-10-23 16:07:11 | 显示全部楼层
我的意思是用(vla-put-type e acQuadSplinePoly)是不是快一些?请G版主帮忙!
发表于 2014-10-23 19:10:56 | 显示全部楼层
  1. (defun Hdgxhs(lst bh h blc / xk LAY e)
  2.   (if(not(tblsearch"appid""SOUTH"))(regapp "SOUTH"))
  3.   (setq sw 34.26 BL (/ blc 1000.0)
  4.         LAY(if(>= h sw)"DGX""DSX")
  5.         XK(*(IF(=(rem h 5)0)0.3 0.15)BL)
  6.         e(ENTMAKEx(LIST'(0 . "POLYLINE")'(100 . "AcDbEntity")'(100 . "AcDb2dPolyline")
  7.                (cons 8 LAY)
  8.                (cons 6 (if(>= h sw)"CONTINUOUS""X11"))
  9.                (cons 62 (IF(=(rem h 5)0)3 1))
  10.                (cons 70 (+ 4 bh)))))
  11.   (foreach x lst(entmakex(list'(0 . "VERTEX")(list 10 (car x)(cadr x) h)(cons 40 xk)(cons 41 xk))))
  12.   (ENTMAKE'((0 . "seqend")))
  13.   (entmod(append(entget e)(list(list -3(list"SOUTH"(cons 1000(cond((and(=(rem h 5)0)(="DGX"LAY))"201102")
  14.         ((and(/=(rem h 5)0)(="DGX"LAY))"201101")
  15.         ((and(=(rem h 5)0)(="DSX"LAY))"186302")
  16.         ((and(/=(rem h 5)0)(="DSX"LAY))"186301"))))))))
  17. )
 楼主| 发表于 2014-10-23 21:02:11 | 显示全部楼层
十分感谢!程序写的太棒了!
但,仍然没有解决拟合问题(查特性时是拟合了,但依然是折线),而且扩展属性也没有加进去。
速度用了9秒(7000个三角形的等高线)。我那个如果屏蔽掉拟合那一句,即
(command "_pedit" e "s" "L" "on" ""),只要8秒,一加上这一句就达到14秒,我嫌他用时太长,故求助!
再次谢谢你!
GMT+8, 2025-5-23 23:16 , Processed in 0.171079 second(s), 26 queries , Gzip On.
