- 积分
- 11082
- 明经币
- 个
- 注册时间
- 2011-4-20
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
(defun c:tt (/ d r ss n obj atts)
(while (setq d (tblnext "block" (null d)))
(setq r (cons (cdr (assoc 2 d)) r))
(and r
(setq filename (getfiled "属性输出文件名" "" "csv" 1))
(if filename
(setq f (open filename "w"))
(foreach name r
(setq ss (ssget "X" '((0 . "INSERT"))));选择对象,修改这里.
;(ssget ss(SSGET "X" '((0 . "INSERT") (8 . "目录")(66 . 1)) )) ;怎么全选目录这个属性块
(if ss
(setq atts (append
(vlax-invoke (setq obj (vlax-ename->vla-object (ssname ss 0))) 'GetConstantAttributes)
(vlax-invoke obj 'GetAttributes)
(princ "序号," f)
(foreach att atts
(princ (vla-get-TagString att) f)
(princ "," f)
);求出属性列表,写表头
(princ "\n" f)
(setq n -1)
(repeat (sslength ss)
(setq obj (vlax-ename->vla-object (ssname ss (setq n (1+ n)))))
(setq atts (append
(vlax-invoke obj 'GetConstantAttributes)
(princ (1+ n) f) (princ "," f)
(foreach att atts
(princ (vla-get-TextString att) f) (princ "," f)
(princ "\n" f);写出属性值
(close f)
有几个问题:
1:现在提取的数据会重复3次!
2:能否只提取 目录 这个属性块的值,我改了无法实现
3:能不能实现批量提取一个文件夹的数据!
