查看: 1711|回复: 5
[源码] 简单的自由移动复制
发表于 2014-10-26 10:03:44 | 显示全部楼层 |阅读模式
(defun c:csedit ( / BIAOJI MSG PT PT1 SS1cscopy inimsg)
(setvar "cmdecho" 0)
(setq ss1 (ssget))
(setq pt (getpoint "\n基准点:"))
(setq msg "\n移动到[P基准点/C复制/R旋转/S比例/J镜像/E退出]<退出>")
(setq inimsg "P基准点 C复制 R旋转 S比例 J镜像 E退出")
(setq cssopy nil)
(setq biaoji t)
(while biaoji
   (initget inimsg)
   (setq pt1 (ACET-SS-DRAG-MOVE ss1 PT msg t 0))
   (cond
     ((= (type pt1) 'list)
      (if cscopy
          (command "copy" ss1 "" ptpt)
      (command "move" ss1 "" pt pt1)
      (setq pt pt1)
     ((= pt1 "P基准点")
      (if (setq pt1 (getpoint pt "\n基准点:"))
          (setq pt pt1)
     ((= pt1 "C复制")
      (setq cscopy t)
      (setq msg "\n复制到[P基准点/M移动/R旋转/S比例/J镜像/E退出]<退出>")
      (setq inimsg "P基准点 M移动 R旋转 S比例 J镜像 E退出")
     ((= pt1 "M移动")
      (setq cscopy nil)
     ((= pt1 "R旋转")
      (if (setq pt1 (ACET-SS-DRAG-rotate ss1 PT "\n旋转角度:" t0))
           (command "rotate" ss1 "" pt (rtod pt1))
     ((= pt1 "S比例")
      (if (setq pt1 (ACET-SS-DRAG-scale ss1 PT "\n比例系数:" t0))
            (command "scale" ss1 ""pt pt1)
     ((= pt1 "J镜像")
      (if (setq pt1 (getpoint PT "\n对称线:"))
            (command "MIRROR" ss1 ""pt pt1 "y")
     ((or (= pt1 "E退出") (not pt1))
      (setq biaoji nil)
(setvar "cmdecho" 1)
发表于 2015-9-6 22:24:19 来自手机 | 显示全部楼层
安装 E T才识别A C E T吧
发表于 2014-10-26 10:31:12 | 显示全部楼层
这种方式是不是更快捷些呢
(princ "\n右键1,左右键2,左键两次3,空格4,按0输入数量")
(setq S?L (grread))
(cond
((= (car S?L) 25) ())                ;右键
((= (car S?L) 3) (S?L2))        ;左键
((= (cadr S?L) 32) (setq SL 4))        ;空格
((= (cadr S?L) 48) (S?LX))      ;0
((= (cadr S?L) 50) (setq SL 2))
((= (cadr S?L) 51) (setq SL 3))
((= (cadr S?L) 52) (setq SL 4))
((= (cadr S?L) 53) (setq SL 5))
((= (cadr S?L) 54) (setq SL 6))
((= (cadr S?L) 55) (setq SL 7))
((= (cadr S?L) 56) (setq SL 8))
((= (cadr S?L) 57) (setq SL 9))
发表于 2014-10-26 19:44:19 | 显示全部楼层
基准点:; 错误: no function definition: ACET-SS-DRAG-MOVE
好像有错误
 楼主| 发表于 2014-10-27 08:47:24 | 显示全部楼层
估计你安装ACAD时没有安装ET工具
 楼主| 发表于 2014-10-27 08:48:53 | 显示全部楼层
三个核心函数:
ACET-SS-DRAG-MOVE
ACET-SS-DRAG-rotate
ACET-SS-DRAG-scale
GMT+8, 2025-9-29 03:21 , Processed in 0.171948 second(s), 28 queries , Gzip On.
