查看: 1202|回复: 3
[已解答] lisp怎么去创建一个文件夹
发表于 2014-10-31 11:39:56 | 显示全部楼层 |阅读模式
lisp怎么去创建一个文件夹
发表于 2014-10-31 11:54:06 | 显示全部楼层
;;to Create a new foler 创建文件夹
(setq *shell (vlax-create-object "Shell.Application"))
(setq root (vlax-invoke *shell 'namespace "d:\\"))
(vlax-invoke root 'newfolder "test")
发表于 2014-10-31 13:12:44 | 显示全部楼层
如果有 DosLib 则可用
(dos_mkdir "D:\\temp\\")
发表于 2014-10-31 13:23:09 | 显示全部楼层
vl-mkdir
Creates a directory
(vl-mkdir directoryname)
Arguments
directoryname
The name of the directory you want to create.
Return Values
T if successful, nil if the directory exists or if unsuccessful.
Examples
Create a directory named mydirectory:
_$ (vl-mkdir "c:\\mydirectory”)
T
多看帮助.....
GMT+8, 2025-5-23 23:10 , Processed in 0.180074 second(s), 25 queries , Gzip On.
