查看: 2572|回复: 8
[源码] 插入相对路径的外部参照,高手们帮助优化优化
发表于 2014-11-10 14:54:31 | 显示全部楼层 |阅读模式
  1. (defun c:tt ( / ent elist blkdef path)
  2.   (vl-load-com)
  3.   (command "-xref" "A" (getfiled "选择要编辑的文件" (getvar "DWGPREFIX") "dwg" 0) (getpoint "指定插入点") "1" "" "0")
  4.   (setq ent (entget (ssname (ssget "L" '((0 . "insert"))) 0)))
  5. (setq obj (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) (cdr (assoc 2 ent)))
  6. )
  7.           (setq elist (entget (tblobjname "block" (cdr (assoc 2 ent))))) ;_获取参照图块的图元表
  8.           (setq blkdef (vlax-ename->vla-object (cdr (assoc 330 elist))))
  9.           (setq path (vla-get-path blkdef)) ;_取得外部参照的路径
  10.           (setq path (vl-filename-base path)) ;_去掉文件的路径和扩展名,返回文件的名称
  11.           (vla-put-path blkdef (strcat ".\" path ".dwg")) ;_参照图块路径改为“相对路径
  12.   (command "_xref" "r" "*")
  13.   (princ)
  14. )
如何把command命令变为vlx形式?
发表于 2015-4-6 12:46:34 | 显示全部楼层
不错,非常好用。
发表于 2019-10-30 00:16:29 来自手机 | 显示全部楼层
谢谢分享,学习了
发表于 2019-12-9 15:47:21 | 显示全部楼层
无法使用,错误信息:
输入中的点位置不正确
发表于 2020-10-26 08:52:50 | 显示全部楼层
;改一下,增加如果参照存在,只改路径,增加支持父目录,子目录,孙目录。。。。。。。
(defun c:tt (/ file scale1 pt0 i total ss filename ent obj elist blkdef)
(vl-load-com)
(defun ffg-path-xiangdui (path-file / tst m m2 ffg n n2 path3 path2 temp xpath path-xiangdui)
  (setq tst nil
    m 0
  (setq ffg (getvar "dwgprefix"))
  (setq m (vl-string-mismatch ffg path-file 0 0))
  (if (>= m (strlen ffg))
    (setq tst t)
    (setq n 0
      n2 0
      path3 ""
    (setq path2 (substr ffg (1+ m)))
    (setq m2 (strlen path2))
    (repeat m2
     (setq temp (ascii (substr path2 (- m2 n) 1)))
     (if (= temp 92)
      (setq n2 (+ 1 n2))
     (setq n (+ 1 n))
    (repeat n2
     (setq path3 (strcat ".." (chr 92) path3))
  (setq xpath (substr path-file (1+ m)))
  (if (= xpath "")
    (setq path-xiangdui (strcat "." (chr 92) xpath))
    (if tst
     (setq path-xiangdui (strcat path3 xpath))
  path-xiangdui
(setvar "cmdecho" 0)
(if (setq file (getfiled "选择参照文件" (strcat (getvar "dwgprefix") "\\") "dwg" 16))
   (if (= (tblobjname "block" (vl-filename-base file)) nil)
     (setq scale1 (getvar "userr4"))
     (if (equal scale1 0 0.0001)
       (setq scale1 1.00)
       (setvar "userr4" scale1)
     (setq scale1 (getreal (strcat "\n请输入图形放大系数 < " (rtos scale1 2 2) " >:"))
       scale1 (if scale1
           scale1
           (getvar "userr4")
     (setq pt0 (getpoint "\n指定插入点:"))
     (setq i 0
       total 0
     (setq ss (ssget "x" '((0 . "insert"))))
     (repeat (sslength ss)
      (setq obj (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) (cdr (assoc 2 (entget (ssname ss i))))))
      (if (and
       (= (vla-get-name obj) (vl-filename-base file))
       (= (vla-get-isxref obj) :vlax-true)
    (setq filename (vla-get-name obj))
    (vla-put-path obj (ffg-path-xiangdui file))
    (setq total (1+ total))
      (setq i (1+ i))
     (prompt (strcat "\n参照已经存在,仅仅修改路径。修改了 " (itoa total) " 个名称为\" " filename " \"的参照块路径."))
(if pt0
   (command "-xref" "a" file "s" scale1 "r" "0.0" pt0)
   (setq obj (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) (cdr (assoc 2 ent))))
   (vla-put-path blkdef (ffg-path-xiangdui file))
(setvar "cmdecho" 1)
moshouhot + 1
 楼主| 发表于 2020-11-3 10:39:14 | 显示全部楼层
(defun c:tt (/ fi ...
感谢完善!!!
发表于 2022-10-26 18:49:50 | 显示全部楼层
好用,特来表示感谢。
发表于 2024-1-17 14:50:34 | 显示全部楼层
请问您这个代码,只能给添加dwg格式的外部参照,能不能扩展到PDF、IMG、PNG 这几个文件上呢?
发表于 2024-4-13 13:40:26 | 显示全部楼层
感谢大佬分享
GMT+8, 2025-6-13 18:32 , Processed in 0.184273 second(s), 30 queries , Gzip On.
