查看: 1780|回复: 5
大虾们,帮我完善程序——
发表于 2003-10-13 15:39:00 | 显示全部楼层 |阅读模式
该程序用funjs运行。
表达式若是(cen+cen)/2时,怎样解决?????
 楼主| 发表于 2003-10-13 15:43:00 | 显示全部楼层
啊,我上传文件没成功!
怎么上传的呀?
发表于 2003-10-13 16:09:00 | 显示全部楼层
浏览文件后,点击上传,成功后再发表
 楼主| 发表于 2003-10-13 16:48:00 | 显示全部楼层
谢谢meflying大哥。
 楼主| 发表于 2003-10-13 16:49:00 | 显示全部楼层
怎么还是没有呢?
 楼主| 发表于 2003-10-13 16:55:00 | 显示全部楼层
算了,我把内容COPY下来了:
;;;DCL文件
dcl_settings : default_dcl_settings { audit_level = 0; }
kr_cal : dialog{
label="表达式计算器 v1.0               *奎容CAD*   tukuitk制作";
      :column{
          :edit_box{label="请输入表达式:";  key="biaodashi"; edit_width=50;  fixed_width=true;}
          spacer;
          :edit_box{label="计 算 结 果 为:";  key="jieguo"; edit_width=50;  fixed_width=true;}
      spacer;
      :column{
      : row{
      fixed_width = true;
      alignment = centered;
      :button{ label=/*MSG*/"  计算  "; key = "accept" ;is_default = true;}
      :spacer{ width = 5; }
      :button{ label=/*MSG*/"  取消  "; key= "cancel";}
;;;LSP文件
(defun c:funjs ( / dcl_id dd bds jg)
  (setvar "cmdecho" 0)
  (command "undo" "be")
  (arxload "geomcal" nil)
  (setq dcl_id (load_dialog "js.dcl"))
  (if (not (new_dialog "kr_cal" dcl_id))
    (exit)
  (action_tile
    "accept"
    "(strcat
    (setq jg (rtos (c:cal bds)))
    (set_tile \"jieguo\" jg)
  (action_tile "cancel" "(done_dialog 0)")
  (action_tile
    "biaodashi"
    "(setq bds (get_tile \"biaodashi\"))"
  (setq dd (start_dialog))
  (unload_dialog dcl_id)
GMT+8, 2025-5-15 09:37 , Processed in 0.167553 second(s), 27 queries , Gzip On.
