Ã÷¾­CADÉçÇø
 ÕÒ»ØÃÜÂë
 ×¢²á
QQ怬
Ö»ÐèÒ»²½£¬¿ìËÙ¿ªÊ¼
ËÑË÷
²é¿´: 1871|»Ø¸´: 10
[ÌáÎÊ] ΪʲôͼԪ²»ÄÜ׼ȷµØÂäÔÚ¹â±êËùÔڵĵãÉÏ£¿
[¸´ÖÆÁ´½Ó]
·¢±íÓÚ 2014-11-17 21:29:18 | ÏÔʾȫ²¿Â¥²ã |ÔĶÁģʽ
±¾Ìû×îºóÓÉ 669423907 ÓÚ 2014-11-17 21:31 ±à¼­
ÏÂÃæÊÇÎÒ¸ÄÂÛ̳ÉϵÄÒ»¸ö»­UÐͿ׵ijÌÐò£¬ÏÖÔÚ·¢ÏÖÓÐһЩÎÊÌ⣺
ÓÐʱºòUÐͿ׿ÉÒÔ׼ȷµÄ·Åµ½µ±Ç°¹â±êËùÔڵĵãÉÏ£¬ÓÐʱºòÓÖ»áÆ«ÀëÁË£¬ÇëÎÊÕâÊÇʲôԭÒòÔì³ÉµÄÄØ£¿
Íû´óʦÃÇÖ¸µã
(defun c:88();»­UÐÍ¿× http://www.jxcad.com.cn/read.php?tid=430246&keyword=%D1%FC%BF%D7
(command "undo" "be")
(if (not *b*)(setq *b* 1) )
(if (not *a*)(setq *a* 3) )
(setq b (getdist (strcat "\nÇëÖ¸¶¨UÐͿ׵Ŀí¶È <"(rtos *b*)">: ")))
(setq a (getdist (strcat "\nÇëÖ¸¶¨UÐͿ׵ij¤¶È <"(rtos *a*)">: ")))
(if (not b)(setq b *b*)(setq *b* b) )
(if (not a)(setq a *a*)(setq *a* a) )
(if (<= a b)
(setq a (* 3 b)))
(setq k (* 0.05 a));ÖÐÐÄÏßÉì³ö³¤¶È
(setq d (- a b))
(setq dj (getpoint "\n×ó¼ü ©¥£¬ÓÒ¼ü ¨‡"))
(if dj (setq j 0)(setq j (* pi 0.5)))
(setq gbwz (grread 3));¹â±êλÖÃ
(if (member (car gbwz) '(3 5))
(setq p1 (cadr gbwz)));Êó±êλÖÃ
;(setq p1 (getpoint "\nÇëÖ¸¶¨UÐͿ׵ÄÖÐÐĵã:"))
(setq os (getvar "osmode"))
(setvar "osmode" 0)
(setq aa (/ d 2.0) p2 (polar p1 0 aa) p3 (polar p1 pi aa) bb (/ b 2.0))
(setq p4 (polar p3 (* pi 1.5) bb) p5 (polar p2 (* pi 1.5) bb) p6 (polar p3 (* pi 0.5) bb))
(command "pline" p4 "w" "0" "0" p5 "a" "ce" p2 "a" "180" "l" p6 "a" "ce" p3 "a" "180" "l" "")
(command "rotate" "l" "" p1 (* (/ 180 pi) j))
(command "chprop" (entlast) "" "p" "la" (getvar "clayer") "ltscale" (* 0.5 b) "")
(setq la (getvar"clayer"))
(command "layer" "m" "2ÖÐÐÄÏß" "c" "1" "" "lw" "0.13" "" "lt" "CENTER" "" "" "clayer" la)
(command "line" (polar p3 (- pi) (+ (* b 0.5) k)) (polar p2 (* pi 0) (+ (* b 0.5) k)) "")
(command "chprop" (entlast) "" "p" "la" "2ÖÐÐÄÏß" "ltscale" (* 0.5 b) "")
(command "line" (polar p3 (+ (* pi 0.5)) (+ (* b 0.5) k)) (polar p3 (* pi 1.5) (+ (* b 0.5) k)) "")
(command "line" (polar p2 (+ (* pi 0.5)) (+ (* b 0.5) k)) (polar p2 (* pi 1.5) (+ (* b 0.5) k)) "")
(command "undo" "e")
(setvar "osmode" os)
(princ))
±¾Ìû×ÓÖаüº¬¸ü¶à×ÊÔ´
ÄúÐèÒª µÇ¼ ²Å¿ÉÒÔÏÂÔØ»ò²é¿´£¬Ã»ÓÐÕ˺ţ¿×¢²á
"¾õµÃºÃ£¬¾Í´òÉÍ"
»¹Ã»ÓÐÈË´òÉÍ£¬Ö§³ÖÒ»ÏÂ
·¢±íÓÚ 2014-11-18 08:22:53 | ÏÔʾȫ²¿Â¥²ã
(setvar "osmode" 0)
°ÑÕâÁ½¾ä·ÅÔÚgetpioint Ç°ÃæÊÔÒ»ÊÔ
 Â¥Ö÷| ·¢±íÓÚ 2014-11-18 09:08:10 | ÏÔʾȫ²¿Â¥²ã
²Ë¾íÓã ·¢±íÓÚ 2014-11-18 08:22
(setvar "osmode" 0)
ÄÇÑù¾ÍÎÞ·¨²¶×½µ½ÏëÒªµÄµãÁË
·¢±íÓÚ 2014-11-18 09:49:13 | ÏÔʾȫ²¿Â¥²ã
°ÑcommandºóÃæÊǵãµÄÇ°Ãæ¼ÓÉÏ¡°none",ÀýÈ磺
(command "line" "none" (polar p3 (- pi) (+ (* b 0.5) k)) "none" (polar p2 (* pi 0) (+ (* b 0.5) k)) "")
·¢±íÓÚ 2014-11-18 10:59:49 | ÏÔʾȫ²¿Â¥²ã
±¾Ìû×îºóÓÉ ²Ë¾íÓã ÓÚ 2014-11-18 11:19 ±à¼­
ÄãµÄµã²»ÊÇͨ¹ý getpointµÃµ½µÄ£¬¶øÊÇgrread Êó±êµã»÷µãµÃµ½µÄ£¬grreadÊDz»´ø²¶×½¹¦Äܵģ¬ÊÔÒ»ÊÔÏÂÃæµÄ
  1. (defun c:88();»­UÐÍ¿×
  2. (if (not *b*)(setq *b* 1) )
  3. (if (not *a*)(setq *a* 3) )
  4. (setq p1 (getpoint "\nÖ¸¶¨UÐͿ׵ÄÖÐÐĵã"))
  5. (setq b (getdist (strcat "\nÇëÖ¸¶¨UÐͿ׵Ŀí¶È <"(rtos *b*)">: ")))
  6. (setq a (getdist (strcat "\nÇëÖ¸¶¨UÐͿ׵ij¤¶È <"(rtos *a*)">: ")))
  7. (if (not b)(setq b *b*)(setq *b* b) )
  8. (if (not a)(setq a *a*)(setq *a* a) )
  9. (if (<= a b)
  10. (setq a (* 3 b)))
  11. (setq k (* 0.05 a));ÖÐÐÄÏßÉì³ö³¤¶È
  12. (setq d (- a b))
  13. (PRINC "\nÖ¸¶¨·½Ïò: ×ó¼ü ©¥£¬ÓÒ¼ü ¨‡")
  14. (setq gbwz (grread NIL 2));¹â±êλÖÃ
  15. (if (member (car gbwz) '(3 25))
  16. (cond((= (car gbwz) 3)(setq j 0))
  17.      ((= (car gbwz) 25)(setq j (* pi 0.5)))
  18. )
  19. (setq j 0))
  20. (setvar 'cmdecho 0)
  21. (command "undo" "be")
  22. (setq os (getvar "osmode"))
  23. (setvar "osmode" 0)
  24. (setq aa (/ d 2.0) p2 (polar p1 0 aa) p3 (polar p1 pi aa) bb (/ b 2.0))
  25. (setq p4 (polar p3 (* pi 1.5) bb) p5 (polar p2 (* pi 1.5) bb) p6 (polar p3 (* pi 0.5) bb))
  26. (command "pline" p4 "w" "0" "0" p5 "a" "ce" p2 "a" "180" "l" p6 "a" "ce" p3 "a" "180" "l" "")
  27. (command "rotate" "l" "" p1 (* (/ 180 pi) j))
  28. (command "chprop" (entlast) "" "p" "la" (getvar "clayer") "ltscale" (* 0.5 b) "")
  29. (setq la (getvar"clayer"))
  30. (command "layer" "m" "2ÖÐÐÄÏß" "c" "1" "" "lw" "0.13" "" "lt" "CENTER" "" "" "clayer" la)
  31. (command "line" (polar p3 (- pi) (+ (* b 0.5) k)) (polar p2 (* pi 0) (+ (* b 0.5) k)) "")
  32. (command "rotate" "l" "" p1 (* (/ 180 pi) j))
  33. (command "chprop" (entlast) "" "p" "la" "2ÖÐÐÄÏß" "ltscale" (* 0.5 b) "")
  34. (command "line" (polar p3 (+ (* pi 0.5)) (+ (* b 0.5) k)) (polar p3 (* pi 1.5) (+ (* b 0.5) k)) "")
  35. (command "rotate" "l" "" p1 (* (/ 180 pi) j))
  36. (command "chprop" (entlast) "" "p" "la" "2ÖÐÐÄÏß" "ltscale" (* 0.5 b) "")
  37. (command "line" (polar p2 (+ (* pi 0.5)) (+ (* b 0.5) k)) (polar p2 (* pi 1.5) (+ (* b 0.5) k)) "")
  38. (command "rotate" "l" "" p1 (* (/ 180 pi) j))
  39. (command "chprop" (entlast) "" "p" "la" "2ÖÐÐÄÏß" "ltscale" (* 0.5 b) "")
  40. (command "undo" "e")
  41. (setvar "osmode" os)
  42. (setvar 'cmdecho 1)
  43. (princ))
·¢±íÓÚ 2014-11-18 11:12:21 | ÏÔʾȫ²¿Â¥²ã
°Ñ(if (member (car gbwz) '(3 5))(setq p1 (cadr gbwz)))Õâ¾ä¸ÄΪ
(if (member (car gbwz) '(3 5))(setq p1 (OSNAP(cadr gbwz) "endp,midp,center")))
 Â¥Ö÷| ·¢±íÓÚ 2014-11-18 20:00:20 | ÏÔʾȫ²¿Â¥²ã
HGQ8888 ·¢±íÓÚ 2014-11-18 11:12
(if (member (car gbwz) '(3 5))(setq  ...
лл´óʦ°ïÖú£¬ÄãµÄ·½·¨ºÜÓÐÓÃ
 Â¥Ö÷| ·¢±íÓÚ 2014-11-18 20:04:56 | ÏÔʾȫ²¿Â¥²ã
²Ë¾íÓã ·¢±íÓÚ 2014-11-18 10:59
лл£¬ÎÒµÄÄ¿µÄÊÇΪÁËʡȥָ¶¨Î»ÖÃÕâÒ»²½£¬£¬£¬£¬£¬£¬£¬£¬£¬£¬£¬£¬
°´ÕÕÕâÖÖģʽ£¬¿ÉÒÔÌ×µ½ºÜ¶àС³ÌÐòÀÓÃÆðÀ´ºÜ˳ÊÖµÄ
(defun cishu()
(setq cishu? (getpoint "\n×ó¼ü1´Î£¬ÓÒ¼üÁ¬Ðø"))
(if (member (car gbwz)'(3 5))
(setq od (osnap(cadr gbwz)"endp,midp,center,node,quadrant,intersection,perpendicular")))
(if (= od nil)(setq od (cadr gbwz)))
(if cishu?
(command "copybase" od ss "" "copy" ss "" od)        ;×ó¼ü
(command "copybase" od ss "" "copy" ss "" "m" od);ÓÒ¼ü
)(princ))
 Â¥Ö÷| ·¢±íÓÚ 2014-11-18 20:06:36 | ÏÔʾȫ²¿Â¥²ã
±¾Ìû×îºóÓÉ 669423907 ÓÚ 2014-11-18 20:09 ±à¼­
aihuyujian ·¢±íÓÚ 2014-11-18 09:49
(command "line" "none" (polar p3 (- pi) (+ (* b 0.5) k))  ...
Õâ¸öÓ¦¸Ã¸ú·ÅÔÚµã»÷ºó£¬»æÍ¼Ç°ÊÇÒ»ÑùµÄЧ¹û£¬ÊÔ¹ýÁË£¬²»ÐÐ
 Â¥Ö÷| ·¢±íÓÚ 2014-11-18 20:15:30 | ÏÔʾȫ²¿Â¥²ã
˳±ãÇë½Ìһϣ¬µ±·ûºÏ (if (<= a b)(setq a (* 3 b))) Ìõ¼þʱ£¬ÔõÑù°Ñ a ÖµËÄÉáÎåÈëÈ¡ÕûÄØ£¿
µãÆÀ
(setq a (fix (* 3 b)))  ·¢±íÓÚ 2014-11-18 21:42
ÄúÐèÒªµÇ¼ºó²Å¿ÉÒÔ»ØÌû µÇ¼ | ×¢²á
±¾°æ»ý·Ö¹æÔò
СºÚÎÝ|ÊÖ»ú°æ|CADÂÛ̳|CAD½Ì³Ì|CADÏÂÔØ|ÁªÏµÎÒÃÇ|¹ØÓÚÃ÷¾­|Ã÷¾­Í¨µÀ ( ÔÁICP±¸05003914ºÅ )
©2000-2023 Ã÷¾­Í¨µÀ °æÈ¨ËùÓÐ ±¾Õ¾´úÂ룬ÔÚδȡµÃ±¾Õ¾¼°×÷ÕßÊÚȨµÄÇé¿öÏ£¬²»µÃÓÃÓÚÉÌÒµÓÃ;
GMT+8, 2025-5-23 17:21 , Processed in 0.218760 second(s), 28 queries , Gzip On.
¿ìËٻظ´ ·µ»Ø¶¥²¿ ·µ»ØÁбí
