查看: 1130|回复: 2
[提问] 读得到坐标就是没有获得当前文件名,求帮忙
发表于 2014-11-24 20:42:30 | 显示全部楼层 |阅读模式
(defun c:tt()
   (setvar "cmdecho" 0)
   (setq FIL_PATH "c:\\dwg\\cnc\\")
   (setq FIL_NUM (file_num))
;;;取得文件编号
  (setq file3 (strcat "\n请输入文件名<" FIL_NUM ">:"))
  (setq wj_name (getstring file3))
  (setq file3 (open (strcat FIL_PATH wj_name ".nc") "w"))
  (if (= wj_name "")
    (setq wj_name FIL_NUM)
  (princ "\n请选择要的圆:")
   (setq a (ssget))
   (setq n (sslength a))
   (setq i 0 m 0)
   (repeat n
     (setq en(ssname a i))
     (setq endata(entget en))
     (setq entype(cdr (assoc 0 endata)))
     (if(= entype "CIRCLE")
       (setq x(cadr(assoc 10 endata)))
       (setq y(caddr(assoc 10 endata)))
       (princ "X" file3)
       (princ (rtos x 2 3) file3)
       (princ "  " file3)
       (princ "Y" file3)
       (princ (rtos y 2 3) file3)
       (princ "\n" file3)
       (setq m (+ 1 m))
     (setq i (+ 1 i))
(princ (strcat "\n共有<" (itoa m) ">孔被选择!"))
(close file3)
(prin1)
发表于 2014-11-24 21:43:04 | 显示全部楼层
  1. (defun c:tt()
  2.   (setq FIL_PATH "c:\\dwg\\cnc\")
  3.   (setq FIL_NUM (getvar "DWGNAME"));;;当前文件名
  4.   (setq FIL_NUM (substr FIL_NUM 1 (- (strlen FIL_NUM) 4)))
  5.   (setq wj_name (getstring (strcat "\n请输入文件名<" FIL_NUM ">:")))
  6.   (if (= wj_name "") (setq wj_name FIL_NUM))
  7.   (setq file3 (open (strcat FIL_PATH wj_name ".nc") "w"))
  8.   (if (and (princ "\n请选择要的圆:")
  9.    (setq a (ssget '((0 . "CIRCLE"))))) (progn
  10.    (setq i 0)
  11.    (repeat (sslength ss)
  12.      (setq pt (cdr(assoc 10 (entget (ssname a i)))))
  13.      (princ "X" (rtos (car pt) 2 3) "  Y" (rtos (cadr pt) 2 3) "\n" file3)
  14.      (setq i (1+ i))
  15.    )
  16.    (princ (strcat "\n共有<" (itoa i) ">孔被选择!"))
  17.    (close file3)
  18.   ))
  19.   (prin1)
  20. )
 楼主| 发表于 2014-11-25 09:25:46 | 显示全部楼层
ZZXXQQ 发表于 2014-11-24 21:43
错误: 参数类型错误: FILE "-104.400"
不行。不要带有.dwg
程序改了,再试试。  发表于 2014-11-25 21:17
GMT+8, 2025-5-23 17:01 , Processed in 0.360663 second(s), 25 queries , Gzip On.
