查看: 987|回复: 0
[提问] 两对象间距离最小改善
发表于 2014-11-28 12:54:31 | 显示全部楼层 |阅读模式
          图一
                      图二
(defun c:dp  (/ CURVE1 CURVE2 D L1 L2 OBJ1 OBJ2 DATA P L P1 P2)
  (setq
        curve1 (car (entsel "\n选取对象一:"))
        curve2 (car (entsel "\n选取对象二:"))
  (if (vlax-invoke
        (vlax-ename->vla-object curve1)
        'IntersectWith
        (vlax-ename->vla-object curve2)
        acExtendNone)
    (princ "\n曲线相交")
       (setq d 0.01)
      (setq l1 (vlax-curve-getDistAtParam curve1 (vlax-curve-getEndParam curve1))
            l2 (vlax-curve-getDistAtParam curve2 (vlax-curve-getEndParam curve2))
      (if (< l1 l2) (setq obj1 curve1 obj2 curve2)
                    (setq obj1 curve2 obj2 curve1))
      (setq data (list (setq p (vlax-curve-getStartPoint obj1))
                               (vlax-curve-getClosestPointTo obj2 p)))
      (setq l d)
      (while (< l (min l1 l2))
        (setq p1 (vlax-curve-getpointatdist obj1 l)
              p2 (vlax-curve-getClosestPointTo obj2 p1)
        (if (< (distance p1 p2) (apply 'distance data))
          (setq data (list p1 p2))
        (setq l (+ l d))
      (setq p1 (vlax-curve-getEndPoint obj1)
      (entmake (list '(0 . "line")
                     '(100 . "AcDbEntity")
                     '(62 . 3)
                     (cons 10 (car data))
                     (cons 11 (cadr data))
   (alert  (strcat "\n两对象最近距离:【"(rtos data 2 3)"】mm"))
以上程序是引用“Z版主的”,在图二执行程序后如何才能显示图一的效果,请高手们指点,谢谢
GMT+8, 2025-5-23 17:29 , Processed in 0.250693 second(s), 27 queries , Gzip On.
