查看: 1026|回复: 4
[已解答] 求助:如何取得标注文字大小
发表于 2014-11-28 16:26:34 | 显示全部楼层 |阅读模式
如何取得标注文字大小,下面这个只能取得标注样式文字大小.如果标注手动改过就得不出真正的大小,请高手帮忙.谢谢
(cdr (assoc '140 (tblsearch "DIMstyle" (cdr (assoc '3 ent)))))
发表于 2014-11-28 21:09:01 | 显示全部楼层
  1. (defun c:tt ()
  2. (if (and (setq s1 (entsel "\n选择尺寸: "))
  3. (setq ent (entget(car s1)))
  4. (= (cdr(assoc 0 ent)) "DIMENSION")) (progn
  5. (setq dim (tblsearch "DIMSTYLE" (cdr(assoc 3 ent))))
  6. (setq txt (cdr(assoc 1 ent)))
  7. (if (wcmatch txt "*\\H#*x;*")
  8. (setq h (atof(substr txt (+ (vl-string-position (ascii "H") txt) 2))))
  9. (setq h 1)
  10. )
  11. (* h (cdr(assoc 40 dim)) (cdr(assoc 140 dim)))
  12. ))
  13. )
 楼主| 发表于 2014-11-29 08:48:50 | 显示全部楼层
ZZXXQQ 发表于 2014-11-28 21:09
Z老大:是不是我的CAD有问题,程序还是只能得出样式的大小!
发表于 2014-11-29 16:19:04 | 显示全部楼层
(vla-get-TextHeight (vlax-ename->vla-object (car(entsel))))
 楼主| 发表于 2014-12-1 09:00:02 | 显示全部楼层
谢谢maiko 的帮助.
GMT+8, 2025-5-23 19:01 , Processed in 0.208007 second(s), 31 queries , Gzip On.
