如果你不嫌弃vbs+LISP的话,可以用下面方式简单获取:
 - (or
- (setq wcs (vlax-create-object "Aec32BitAppServer.AecScriptControl.1"))
- (setq wcs (vlax-create-object "ScriptControl"))
- (vlax-put-property wcs "language" "VBScript")
- (setq code "Function GetDays(t1,t2)\nGetDays = DateDiff(\"d\",t1,t2)\nEnd Function")
- (vlax-invoke wcs 'addcode code)
- (princ (vlax-invoke wcs 'run "GetDays" "1949-10-01" "2022-08-01")) ;此处输入两个要求的日期
