查看: 701|回复: 1
[提问] 所有填充对象置后显示
发表于 2014-12-10 16:29:26 | 显示全部楼层 |阅读模式
;;所有填充对象置后显示
(defun c:tt (/ )
(setq *OBJ (vlax-get-acad-object))
  (setq *DOC (vla-get-activedocument *OBJ))
  (setq blocklist (vla-get-blocks *DOC));取得块集合
  (vlax-for block blocklist             ;遍历块集合
    (vlax-for n block                   ;遍历单个块
    (if (= "AcDbHatch" (vla-get-objectname n))
         (command "draworder" n "" "_B")
)麻烦帮看一下有什么问题
发表于 2014-12-10 16:44:25 | 显示全部楼层
command中,一般是ename,而你程序中n是vla
GMT+8, 2025-5-23 17:00 , Processed in 0.170532 second(s), 26 queries , Gzip On.
