查看: 4143|回复: 5
[提问] 如何提取多行文字里面的内容
发表于 2014-12-12 17:25:50 | 显示全部楼层 |阅读模式
请问大神,我如何把{和; 之间的内容删掉啊,字符串如下:
14123{\fArial Black|b0|i0|c0|p34;1+63}3.036
发表于 2014-12-16 14:53:53 | 显示全部楼层
  1. (defun mtext2txt(s / ob)
  2.   (vlax-put-property(setq ob(vlax-create-object"Vbscript.RegExp"))"IgnoreCase"0)
  3.   (vlax-put-property ob "Global" 1)
  4.   (setq s(mapcar'(lambda(x y)(vlax-put-property ob"Pattern"x)(setq s(vlax-invoke-method ob"Replace"s y)))
  5.                 '("\\\\\\\\""\\\\{""\\\\}""\\\\pi(.[^;]*);""\\\\pt(.[^;]*);""\\\\S(.[^;]*)(\\^|#|\\\\)(.[^;]*);"
  6.                   "(\\\\F|\\\\f|\\\\C|\\\\H|\\\\T|\\\\Q|\\\\W|\\\\A)(.[^;]*);""(\\\\L|\\\\O|\\\\l|\\\\o)""\\\\~"
  7.                   "\\\\P" "\n" "({|})" "\\x01" "\\x02" "\\x03")(list(CHR 1)(CHR 2)(CHR 3)"""""""""""" (chr 13) "" "" "\\" "{" "}")))
  8.   (if ob(vlax-release-object ob))
  9.   (last s))
这是根据MCCAD的修改的,其中换行符替换为(chr 13)是因为我有特殊用途,如果用不着,可以把它替换为""
发表于 2022-5-21 22:15:02 | 显示全部楼层
如果多行文字设置了行间距,代码提取会出错,在你的基础上修改了一下,可以测试一下
  1. ;;测试文件
  2. (defun C:test2()
  3.   (mtext2txt2 (vlax-get (vlax-ename->vla-object (car(entsel "\n选择多行文字"))) 'TextString))
  4. )
  5. ;;说明:提取多行文字的内容(去除所有格式)
  6. ;;参数:s:多行文字的值
  7. ;;返回:string
  8. ;;换行符替换为""(如果想替换成其他值,修改倒数第4行的 “(chr 0)”为其他值)
  9. ;;在llsheng_73的基础上修改,参考http://bbs.mjtd.com/forum.php?mod=viewthread&tid=112421
  10. (defun mtext2txt2(s / ob)
  11.   (vlax-put-property (setq ob(vlax-create-object"Vbscript.RegExp")) "IgnoreCase" 0)
  12.   (vlax-put-property ob "Global" 1)
  13.   (setq s (mapcar '(lambda(x y)(vlax-put-property ob"Pattern"x) (setq s (vlax-invoke-method ob "Replace" s y)))
  14.         '("\\\\\\\\""\\\\{""\\\\}""\\\\p(.[^;]*);""\\\\S(.[^;]*)(\\^|#|\\\\)(.[^;]*);"
  15.            "(\\\\F|\\\\f|\\\\C|\\\\H|\\\\T|\\\\Q|\\\\W|\\\\A)(.[^;]*);""(\\\\L|\\\\O|\\\\l|\\\\o)""\\\\~"
  16.            "\\\\P" "\n" "({|})" "\\x01" "\\x02" "\\x03")(list (CHR 1) (CHR 2) (CHR 3)"" "" "" "" "" (chr 0) "" "" "\\" "{" "}")))
  17.   (if ob (vlax-release-object ob))
  18.   (last s)
  19. )
发表于 2014-12-13 08:07:54 | 显示全部楼层
对于Mtxet,建议如下,这样你就不用去除前面的控制符了
(setq obj(vlax-ename->vla-object e))
(setq tex (vlax-get obj 'TextString))
这样如果有控制字符,它还是在里边的,同样需要去除  发表于 2014-12-14 21:55
发表于 2014-12-12 18:44:28 | 显示全部楼层
论坛里有发过,仔细找找
发表于 2014-12-16 17:26:28 | 显示全部楼层
强,如果要保留图片所示的公差内容呢?
GMT+8, 2025-7-15 06:32 , Processed in 0.216919 second(s), 35 queries , Gzip On.
