- ;多段线边长标注.lsp
- ;本源代码由 Gu_xl 编写发布! 联系方式: Email: Gu_xl@sohu.com
- ;;多段线边长标注2011.4
- (defun c:tt (/ obj pianju sHandle pt np gx bj np xc rr cp n ang1 zjp ms AddText)
- ;;;构造text
- (defun AddText (obj TextString InsertionPoint Height xz kb qx Alignment style / obj1 err)
- (setq obj1 (vla-addtext obj TextString (vlax-3d-point InsertionPoint) Height))
- (vla-put-Rotation obj1 xz)
- (vla-put-ScaleFactor obj1 kb)
- (vla-put-ObliqueAngle obj1 qx)
- (vla-put-alignment obj1 Alignment)
- (if (/= Alignment acAlignmentLeft)
- (vla-put-TextAlignmentPoint obj1 (vlax-3d-point InsertionPoint))
- (vla-put-InsertionPoint obj1 (vlax-3d-point InsertionPoint))
- (VL-CATCH-ALL-APPLY 'vla-put-StyleName (list obj1 style))
- obj1
- (setq pi2 (/ pi 2))
- (setq ms (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-acad-object))))
- (while (setq pen (car (entsel "\n选择多段线:")))
- (setq bcHeight 0.28 ;_ 字高
- kgb 0.8 ;_ 宽高比
- Style "standard" ;_ 字体
- ZJWS 2 ;_ 注记位数
- DimScale 1 ;_ 边长尺度,若单位为mm,该值为1000
- flag nil ;_ 标注在多段线走向的右侧,T 左侧
- ) ;_ setq
- (setq pianju (* bcHeight 0.7)) ;_ 边长离线距离
- (setq obj (vlax-ename->vla-object pen)
- n 0)
- (while (and (setq pt (vlax-curve-getPointAtParam obj n))
- (setq np (vlax-curve-getPointAtParam obj (1+ n)))
- ) ;_ 结束and
- (if (/= 0.0 (setq bugle (vla-GetBulge obj n)))
- (progn
- (setq midpt (vlax-curve-getPointAtParam obj (+ 0.5 n))
- bj (* (atan (abs bugle)) 4)
- xc (* 0.5 (distance Pt np))
- gg (abs (* bugle xc))
- rr (/ (+ (* xc xc) (* gg gg)) (* 2 gg))
- ang1 (angle pt np)
- cp (polar Pt ang1 xc)
- cp (polar midpt (angle midpt cp) rr)
- bc (rtos (/ (- (vlax-curve-getDistAtParam obj (1+ n)) (vlax-curve-getDistAtParam obj n)) DimScale) 2 ZJWS)
- (if flag
- (setq zjp (polar midpt (cond ((> bugle 0)(angle midpt cp))(t (angle cp midpt))) pianju))
- (setq zjp (polar midpt (cond ((> bugle 0)(angle cp midpt))(t (angle midpt cp))) pianju))
- (if (not (or (and (>= ang1 0) (< ang1 (* 0.666666 pi))) (and (> ang1 (* 1.666666 pi)) (< ang1 (* 2.0 pi)))))
- (setq ang1 (- ang1 pi))
- (AddText ms bc zjp bcHeight ang1 kgb 0 acAlignmentMiddle Style)
- );progn
- (progn
- (if flag
- (setq zjp (polar midpt (+ pi2 ang1) pianju))
- (setq zjp (polar midpt (- ang1 pi2) pianju))
- (if (not (or (and (>= ang1 0) (< ang1 (* 0.666666 pi))) (and (> ang1 (* 1.666666 pi)) (<= ang1 (* 2.0 pi)))))
- );progn
- ) ;_ 结束if
- (setq n (1+ n))
- ) ;_ 结束while
- (princ)
看看这个gu版的是不是您想要的。 |
