查看: 1629|回复: 2
[提问] 为什么用lisp写的工具栏,转化成vlx之后就无法加载了?
发表于 2014-12-24 10:59:13 | 显示全部楼层 |阅读模式
  1. (defun create_toolbar (/ file lst x lsfile)
  2.   (setvar "cmdecho" 0)
  3.   (vl-load-com)
  4.   (if (not (menugroup "SLtool"))  ; 判断cad是否加载temptoolbar工具
  5.     (progn          ; 如果没加载,则自动执行下面程序
  6.       (setq file (open "SLtool.mnu" "W"))    ;创建工具栏
  7.       (foreach x '("***MENUGROUP=SLtool\n\n***TOOLBARS\n**SLtool"
  8. "ID_ZCT001      [_Toolbar("算量工具", _Right, _show, 0, 0, 1)]"
  9. "ID_SL011           [_Flyout("全开","ua","ua",_OtherIcon,SLtool01)]"
  10. "ID_SL02          [_Flyout("统长", "q","q",_OtherIcon,SLtool02)]"
  11. "ID_SL03          [_Flyout("到xls", "dx","dx",_OtherIcon,SLtool03)]"
  12. "ID_SL05          [_Flyout("查找", "t","t",_OtherIcon,SLtool05)]"
  13. "ID_SL012           [_Button("按层选",\ "RCDATA_16_PLANESURF", "RCDATA_16_PLANESURF")]^C^Cv"
  14. "ID_SL012          [_Button("多线", "RCDATA_16_OSNPAR", "RCDATA_16_OSNPAR")]^C^Cb"
  15. "ID_SL012          [_Button("新层", "RCDATA_16_CURLAY", "RCDATA_16_CURLAY")]^C^Cxx"
  16. "ID_SL012           [_Button("块数量", "RCDATA_16_DONUT", "RCDATA_16_DONUT")]^C^Ckk"
  17. "ID_Dimlinear          [_Button("距离", "RCDATA_16_DIMLIN", "RCDATA_16_DIMLIN")]^C^Cdd"
  18. "ID_Dist          [_Button("帮助", "RCDATA_16_PTFY", "RCDATA_16_PTFY")]^C^Chh"
  19. "**SLtool01"
  20. "ID_ZCT001        [_Toolbar("图层", _Floating, _Hide, 10, 340, 1)]"
  21. "ID_SL011        [_Button("全开图层", "RCDATA_16_LAYUNISO", "RCDATA_16_LAYUNISO")]^C^Cua"
  22. "ID_SL012        [_Button("选择关闭", "RCDATA_16_FRZLAY", "RCDATA_16_FRZLAY")]^C^Cqw"
  23. "ID_SL012        [_Button("未选关闭", "RCDATA_16_WLKLAY", "RCDATA_16_WLKLAY")]^C^Cqe"
  24. "**SLtool02"
  25. "ID_ZCT001        [_Toolbar("统计", _Floating, _Hide, 10, 340, 1)]"
  26. "ID_SL012           [_Button("线共长", "RCDATA_16_SPLINE", "RCDATA_16_SPLINE")]^C^Cq"
  27. "ID_SL012           [_Button("算面积", "RCDATA_16_POLYGO", "RCDATA_16_POLYGO")]^C^Caa"
  28. "**SLtool03"
  29. "ID_ZCT001         [_Toolbar("导出", _Floating, _Hide, 10, 340, 1)]"
  30. "ID_SL012          [_Button("到xls","RCDATA_16_TABLESTYLE", "RCDATA_16_TABLESTYLE")]^C^Cdx"
  31. "ID_SL012          [_Button("到txt", "RCDATA_16_NEW", "RCDATA_16_NEW")]^C^Cdt"
  32. "**SLtool05"
  33. "ID_ZCT001       [_Toolbar("文字", _Floating, _Hide, 10, 340, 1)]"
  34. "ID_SL012          [_Button("查找", "RCDATA_16_ZOOPRE", "RCDATA_16_ZOOPRE")]^C^Ct"
  35. "ID_SL012          [_Button("刷子", "RCDATA_16_PURGE", "RCDATA_16_PURGE")]^C^Css"
  36. )
  37. (princ (strcat x "\n") file)   ; 将定义工具栏内容写入mnu文件
  38.       )
  39.       (close file)         ; 关闭mnu文件
  40.       (command "menuload" "SLtool.mnu") ; 加载temptoolbar工具栏
  41.     )
  42.   )
  43.   (command "TOOLBAR" "算量工具" "S") ; 显示工具栏
  44.   (princ)
  45. )
  46. (create_toolbar)  ;开机加载
  47. (defun C:DK() ;意外关闭之后重新打开
  48.   (command "TOOLBAR" "算量工具" "S")
  49. )
发表于 2014-12-24 11:53:12 | 显示全部楼层
估计"SLtool.mnu"不在支持文件目录下
发表于 2018-6-1 07:13:03 | 显示全部楼层
和CAD版本、安装、有关。
GMT+8, 2025-10-25 04:05 , Processed in 0.192600 second(s), 29 queries , Gzip On.
