查看: 1182|回复: 4
[已解答] 关于方向键重复输入值
发表于 2014-12-31 11:00:22 | 显示全部楼层 |阅读模式
以前用AutoCAD2004,命令后输入的值,之后的命令再用到时,用向上的方向键就可以输入,现在我换成了autocad2008后,向上的键变成了坐标点,请问是否有相关的系统变量设置,谢谢!
发表于 2014-12-31 14:26:59 | 显示全部楼层
默认空格不是就是上次输入吗
发表于 2015-1-1 16:20:03 | 显示全部楼层
INPUTHISTORYMODE (System Variable)
Controls the content and location of the user input history.
Type:        Bitcode
Saved in:        Registry
Initial value:        15
The setting is stored as a bitcode using the sum of the following values:
0
No history of recent input is displayed.
1
History of recent input is displayed at the command line or in a dynamic prompt tooltip. Access with the Up Arrow and Down Arrow keys at the Command prompt, or at an input prompt.
2
History of recent input for the current command is displayed in the shortcut menu under Recent Input.
4
History of recent input for all commands in the current session is displayed in the shortcut menu under Recent Input.
8
Markers for recent input of point locations are displayed. Use the arrow keys at the Command prompt for specifying a point location.
发表于 2015-1-1 16:21:44 | 显示全部楼层
这是位值,按你的习惯只需要去除1即可。
一般我也是设置 INPUTHISTORYMODE=14 的。
 楼主| 发表于 2015-1-2 14:29:22 | 显示全部楼层
e2002的回复,正是我要的,谢谢!
GMT+8, 2025-5-23 17:37 , Processed in 0.186187 second(s), 25 queries , Gzip On.
