查看: 959|回复: 0
[讨论] 我也想知道以下这个批量打印程序只能打出第一页就出错
发表于 2015-1-5 16:09:03 | 显示全部楼层 |阅读模式
我也想知道以下这个批量打印程序只能打出第一页就出错:http://bbs.xdcad.net/thread-678828-1-2.html
  1. (defun c:A3DY()
  2.      (vl-load-com)
  3.      (setq A3tz '(((0 0) (420 297)) ((480 0) (900 297)) ((960 0) (1380 297))))
  4.      (setq Doc (vla-get-ActiveDocument (vlax-get-acad-object)))
  5.      (setq Layout (vla-get-ActiveLayout Doc))
  6.      (setq Plot (vla-get-Plot Doc))
  7.      (foreach pts A3tz
  8.          (vla-RefreshPlotDeviceInfo Layout)
  9.          (setq p1 (car pts)  p2(cadr pts))
  10.          (vlax-invoke Layout "SetWindowToPlot" p1 p2)         ;打印范围
  11.          (vlax-put Layout "ConfigName" "HP LJ 5200LX PCL6")   ;打印机
  12.   (vlax-put Layout "StyleSheet" "monochrome.ctb")      ;打印样式表("monochrome.ctb")
  13.   (vlax-put Layout "CanonicalMediaName" "A3")          ;图纸尺寸:A3
  14.   (vlax-put Layout "PlotRotation" 1)                   ;图形方向:横向
  15.   (vlax-put Layout "StandardScale" 1)                  ;缩放方式:自定义比例
  16.   (vlax-put Layout "PaperUnits" 1)                     ;单位:1-毫米
  17.   (vlax-put Layout "PlotType" 4)                       ;打印范围:4-窗口
  18.   (vla-SetCustomScale Layout 1 1)                      ;打印比例
  19.
  20.          ;(vla-DisplayPlotPreview Plot acFullPreview) ;打印预览
  21.   (vla-plotToDevice Plot)                     ;打印
  22.      )
  23.      (vlax-release-object Plot)
  24.      (vlax-release-object Layout)
  25.      (vlax-release-object Doc)
  26.      (princ)
  27. )
GMT+8, 2025-5-23 09:18 , Processed in 0.191424 second(s), 28 queries , Gzip On.
