查看: 1264|回复: 2
[已解答] 谁能根据下面的程序帮我改成个打开指定文件夹的程序,先谢谢了~
发表于 2015-1-7 17:06:09 | 显示全部楼层 |阅读模式
;;;选择文件目录
(defun c:xz1 (/ path dwgname explor)
  (setq explor (findfile"C:\\WINDOWS\\explorer.exe")
  path   (getvar "DWGPREFIX")
;  dwgname (getvar "DWGNAME")
  dwgname (strcat "\"" (getvar "DWGNAME") "\"")
  (cond
    ((and (not (null dos_execute)) explor path dwgname)
     (dos_execute (strcat explor " /e, " path ", /select, " path dwgname)))
    ((and explor path dwgname)
     (startapp (strcat explor " /e, " path ", /select, " path dwgname)))
    (t (princ "\n无法启用资源管理器!"))
  (princ))
发表于 2015-1-8 14:04:48 | 显示全部楼层
  1. (defun c:fa ()
  2. (princ "//打开D盘新建文件夹")
  3. (startapp "explorer"  "D:\\新建文件夹")
  4. (prin1))
 楼主| 发表于 2015-1-9 07:54:10 | 显示全部楼层
菜卷鱼 发表于 2015-1-8 14:04
非常感谢! 很好用~~~~~~~~~~~~~~~~~~~~~
GMT+8, 2025-11-26 13:27 , Processed in 0.168820 second(s), 29 queries , Gzip On.
