查看: 1666|回复: 4
[讨论] 标注打断源码,但不支持UCS
发表于 2015-1-16 12:35:01 | 显示全部楼层 |阅读模式
;;标注打断+连续标注
(vl-load-com)
(defun c:ddr (/ n x ent entl p2 p3 px1 px2 py1 py2 ptdd xl sa pt0 ppt ptdd)
  (setvar "cmdecho" 0)
  (if (setq ent (centsel "\n选择标注 或 <退出>:" "DIMENSION"))
      (setq x         (entget ent)
            entl (cons ent entl)
            p2         (dxf 13 x)
            p3         (dxf 14 x)
            px1         (list (car p2) (/ (+ (cadr p2) (cadr p3)) 2.0))
            px2         (list (car p3) (/ (+ (cadr p2) (cadr p3)) 2.0))
            py1         (list (/ (+ (car p2) (car p3)) 2.0) (cadr p2))
            py2         (list (/ (+ (car p2) (car p3)) 2.0) (cadr p3))
            ptdd (list p2 p3)
            xl         (entget (dxf -2 (tblsearch "block" (dxf 2 x))))
            sa         (abs (sin (angle (dxf 10 xl) (dxf 11 xl))))
      (while (setq pt0 (getpoint "\n取点 或 <退出>:"))
        (command "undo" "be")
        (command ".copy" ent "" "0,0" "@")
        (setq entl (cons (entlast) entl))
        (cond
          ((equal sa 1 1e-6)
           ;;水平
           (setq ptdd (cons (ptper pt0 px1 px2) ptdd)
                 ppt  (lsort ptdd 0)
          ((equal sa 0 1e-6)
           ;;垂直
           (setq ptdd (cons (ptper pt0 py1 py2) ptdd)
                 ppt  (lsort ptdd 1)
          (t
           (setq ptdd (cons (ptper pt0 p2 p3) ptdd)
                 ppt  (lsort ptdd 2)
        (setq ppl (mapcar 'list ppt (cdr ppt))
              n          0
        (repeat        (length ppl)
          (setq        xf  (entget (nth n entl))
                nxf (subst (cons 13 (car (nth n ppl))) (assoc 13 xf) xf)
                wxf (subst (cons 14 (cadr (nth n ppl))) (assoc 14 nxf) nxf)
                n   (1+ n)
          (entmod wxf)
        (command "undo" "e")
    (princ "\n退出")
  (setvar "cmdecho" 1)
(defun centsel (msg f / ent ss)
  (princ msg)
  (while (null ent)
    (setq ss (ssget  (list (cons 0 f))))
    (if        ss
      (setq ent (ssname ss 0))
  (redraw ent 3)
  ent
;;取值dxf
(defun dxf (x e) (cdr (assoc x e)))
;;求垂足
(defun ptper (pt0 pt1 pt2)
  (inters pt0 (polar pt0 (+ (angle pt1 pt2) (/ pi 2)) 1.0) pt1 pt2 nil)
;;排序 0 水平 1 垂直 2 倾斜
(defun lsort (lt i)
  (cond
    ((or (= i 0) (= i 2)) (setq lt (vl-sort lt (function (lambda (e1 e2) (< (car e1) (car e2)))))))
    ((or (= i 1) (= i 2))
     (setq lt (vl-sort lt (function (lambda (e1 e2) (< (cadr e1) (cadr e2))))))
 楼主| 发表于 2015-1-16 12:35:41 | 显示全部楼层
加了
(command "ucs" "w")
(command "ucs" "")
有的时候也要出问题.
发表于 2015-1-16 12:42:22 | 显示全部楼层
这么厉害.
标注打断.
  1. (defun c:cxdd2(/ en lind_db n p10 p13 p14 ptlst pts ss_line)
  2.         (setq en (dx))
  3.         (setq p13 (cx-dxf  13 en)
  4.                 p14 (cx-dxf  14 en)
  5.                 p10 (cx-dxf  10 en)
  6.                 ptlst(get-box en)
  7.                 ss_line(ssget "c"(car ptlst)(cadr ptlst)'((0 . "LINE")))
  8.         )
  9.         (foreach x (cx-ss2en ss_line)
  10.                 (setq lind_db (cx-db x))
  11.                 (setq pts (cons (inters p13 p14 (car lind_db)(cadr lind_db)t)pts))
  12.         )
  13.         (setq pts (append(list p13 p14)pts))
  14.         (setq pts(cx-sort pts "xy" 0.01))
  15.         (entdel en)
  16.         (repeat (setq n(1-(length pts)))
  17.                 (cx-mak-dim (nth n pts)(nth (1- n) pts)p10)
  18.                 (setq n (1- n))
  19.         )
  20. )
这是什么 ?删除了当前选择的  发表于 2015-1-16 13:24
发表于 2015-1-16 15:39:59 | 显示全部楼层
鱼与熊掌 发表于 2015-1-16 12:42
这么厉害.
标注打断.
记得加载我的库
发表于 2024-12-16 17:25:58 | 显示全部楼层
我滴哥啊,我看不明白你的subst到底替换了什么东西为什么可以一个标注变俩,能说说吗。
GMT+8, 2025-5-2 04:29 , Processed in 0.156657 second(s), 25 queries , Gzip On.
