查看: 1317|回复: 5
希望有大神能够帮我修改下VBA程序
发表于 2015-1-23 21:38:56 | 显示全部楼层 |阅读模式
新手小白,为完成课程设计。边看书,边做。为实现自动生成一对斜齿轮,只要出图就行。
思路是先画一个轮齿的齿廓,然后阵列,然后拉伸成为一个实体。
错误可能有点多,望谅解~真心求助。
Private Sub userform1_load()
Me.Left = (Screen.width_me.Width)
Me.top = 0
Me.TextBox7 .Text = 31
Me.TextBox8.Text = 63.91
Me.TextBox9.Text = 67.91
Me.TextBox10.Text = 58.91
Me.TextBox11.Text = 69
Me.TextBox17.Text = 60.91
Me.TextBox12.Text = 99
Me.TextBox13.Text = 204.09
Me.TextBox14.Text = 208.09
Me.TextBox15.Text = 199.09
Me.TextBox16.Text = 64
Me.TextBox18.Text = 202.09
Me.CommandButton1.Caption = "开始"
Me.CommandButton2.Caption = "结束"
Dim z1, d1, da1, df1, db1, b1, ε, θ, α, μ, η As Double
End Sub
Private Sub CommandButton1_Click()
On Error Resume Next
AcadApp.ActiveDocument.Close
AcadApp.Documents.Add
'创建小齿轮
Dim circleObj As AcadCircle
Dim centerpoint(0 To 2) As Double
Dim radius As Double
'定义圆心坐标跟半径
centerpoint(0) = 0#: centerpoint(1) = 0#: centerpoint(2) = 0#
radius = 30.45
'创建圆
Set circleObj = AcadApp.ActiveDocument.ModelSpace.addcircle_(centerpoint, radius)
ZoomAll
z1 = Me.TextBox7
d1 = Me.TextBox8
da1 = Me.TextBox9
df1 = Me.TextBox10
db1 = Me.TextBox17
b1 = Me.TextBox11
ε = (Sqr((df1) ^ 2 - (db1) ^ 2)) / db1
θ = (Sqr((d1) ^ 2 - (db1) ^ 2)) / db1
α = (Sqr((da1) ^ 2 - (db1) ^ 2)) / db1
μ = ε + (θ - ε) / 2
η = θ + (α - θ) / 2
'连接点P1,P2
Dim lineObj0 As AcadLine
Dim p1(0 To 1) As Double
Dim P2(0 To 1) As Double
'定义直线的起点与终点的二维坐标
p1(0) = db1 / 2#: p1(1) = 0#
P2(0) = db1 * (cosε + ε * sinε) / 2#: P2(1) = db1 * (sinε - ε * cosε) / 2#
Set lineObj = AcadApp.activedocumentmodelspace.appline_(p1, P2)
ZoomAll
'连接点P2,P3
Dim lineObj1 As AcadLine
Dim P3(0 To 1) As Double
'定义直线的起点与终点的二维坐标
P3(0) = db1 * (cosμ + μ * sinμ) / 2#: P3(1) = db1 * (sinμ - μ * cosμ) / 2#
Set lineObj = AcadApp.activedocumentmodelspace.appline_(P2, P3)
ZoomAll
'连接点P3,P4
Dim lineObj2 As AcadLine
Dim P4(0 To 1) As Double
'定义直线的起点与终点的二维坐标
P4(0) = db1 * (cosθ + θ * sinθ) / 2#: P4(1) = db1 * (sinθ - θ * cosθ) / 2#
Set lineObj = AcadApp.activedocumentmodelspace.appline_(P3, P4)
ZoomAll
'连接点P4,P5
Dim lineObj3 As AcadLine
Dim P5(0 To 1) As Double
'定义直线的起点与终点的二维坐标
P5(0) = db1 * (cosη + η * sinη) / 2#: P3(1) = db1 * (sinη - η * cosη) / 2#
Set lineObj = AcadApp.activedocumentmodelspace.appline_(P4, P5)
ZoomAll
'连接点P5,P6
Dim lineObj4 As AcadLine
Dim P6(0 To 1) As Double
'定义直线的起点与终点的二维坐标
P6(0) = db1 * (cosα + α * sinα) / 2#: P4(1) = db1 * (sinα - α * cosα) / 2#
Set lineObj = AcadApp.activedocumentmodelspace.appline_(P5, P6)
ZoomAll
λ = π / 2 * z1
γ = Atn((db1 * (sinθ - θ * cosθ) / 2) / (db1 * (cosθ + θ * sinθ) / 2))
δ = λ + γ
'连接点P6,P7
Dim lineObj5 As AcadLine
Dim P7(0 To 1) As Double
'定义直线的起点与终点的二维坐标
P7(0) = da1 * cosδ / 2: P7(1) = da1 * sinδ / 2
Set lineObj = AcadApp.activedocumentmodelspace.appline_(P6, P7)
ZoomAll
Dim mirrorPt1(0 To 1) As Double
Dim mirrorPt2(0 To 2) As Double
mirrorPt1(0) = 0#: mirrorPt1(1) = 0#
mirrorPt2(0) = da1 * cosδ / 2#: mirrorPt2(1) = da1 * sinδ / 2
'镜像P1到P7的连线
Dim mirrorlineObj As AcadLine
Set mirrorlineObj = lineObj.Mirror(mirrorPt1, morrorPt2)
'阵列轮齿齿廓
Dim boxObj As AcadSolid
Dim center(0 To 1) As Double
Dim taperAngle As Double
taperAngle = 0
center(0) = 0#: center(1) = 0#
Set boxObj = Userfrom1.ActiveDocument.ModelSpace.AddBox_(center, (Pi * m) / 2, 4 * m)
Dim retObj As Variant
retObj = boxObj.ArrayPolar(31, 2 * Pi, center)
For I = 0 To 32 - 2 '齿轮齿数为31
    retObj(I).Rotate center, centerpoint, 3.14 / 2
    retObj(I).Update
Next I
'齿廓形成面域
Dim boxObj1 As AcadEntity
Dim regionObj As Variant
regionObj = AcadApp.ActiveDocument.ModelSpace.AddRegion(boxObj)
'定义拉伸
Dim height As Double
Dim taperAngle1 As Double
height = 69
taperAngle = 14.032
'创建面域拉伸实体
Dim solidObj1 As Acad3DSolid
Set solidObj1 = AcadApp.ActiveDocument.ModelSpace.AddExtrudedsolid_(regionObj, height, taperAngle)
'创建大齿轮模型
Dim ucsObj As AcadUCS
Dim origin(0 To 1) As Double
Dim xAxisPoint(0 To 1) As Double
Dim yAxisPoint(0 To 1) As Double
origin(0) = 0: origin(1) = 0
xAxisPoint(0) = 134: xAxisPoint(1) = 0
yAxisPoint(0) = 0: yAxisPoint(1) = 0
Set ucsObj = AcadApp.ActiveDocument.UserCoordinateSystems.Add_(origin, xAxisPoint, yAxisPoint, "UCS1")
AcadApp.ActiveDocument.ActiveUCS = ucsObj
'显示UCS图标
AcadApp.ActiveDocument.ActiveViewport.UCSIconOn = True
AcadApp.ActiveDocument.ActiveViewport.UCSIconAtOrigin = True
Dim circleObj1 As AcadCircle
Dim centerpoint1(0 To 2) As Double
Dim radius1 As Double
'定义圆心坐标跟半径
radius = 101.045
'创建圆
ZoomAll
Dim z2, d2, da2, df2, db2, b2
z2 = Me.TextBox12
d2 = Me.TextBox13
da2 = Me.TextBox14
df2 = Me.TextBox15
db2 = Me.TextBox18
b2 = Me.TextBox16
ε = (((df2) ^ 2 - (db2) ^ 2) ^ -2) / db2
θ = (((d2) ^ 2 - (db2) ^ 2) ^ -2) / db2
α = (((da2) ^ 2 - (db2) ^ 2) ^ -2) / db2
μ = ε + (θ - ε) / 2
η = θ + (α - θ) / 2
'连接点P1,P2
Dim line0 As AcadLine
Dim H1(0 To 1) As Double
Dim H2(0 To 1) As Double
'定义直线的起点与终点的二维坐标
p1(0) = db2 / 2#: p1(1) = 0#
P2(0) = db2 * (cosε + ε * sinε) / 2#: P2(1) = db2 * (sinε - ε * cosε) / 2#
ZoomAll
'连接点P2,P3
Dim line1 As AcadLine
Dim H3(0 To 1) As Double
'定义直线的起点与终点的二维坐标
P3(0) = db2 * (cosμ + μ * sinμ) / 2#: P3(1) = db2 * (sinμ - μ * cosμ) / 2#
ZoomAll
'连接点P3,P4
Dim line2 As AcadLine
Dim H4(0 To 1) As Double
'定义直线的起点与终点的二维坐标
P4(0) = db2 * (cosθ + θ * sinθ) / 2#: P4(1) = db2 * (sinθ - θ * cosθ) / 2#
ZoomAll
'连接点P4,P5
Dim line3 As AcadLine
Dim H5(0 To 1) As Double
'定义直线的起点与终点的二维坐标
P4(0) = db * (cosθ + θ * sinθ) / 2#: P4(1) = db * (sinθ - θ * cosθ) / 2#
P5(0) = db * (cosη + η * sinη) / 2#: P3(1) = db * (sinη - η * cosη) / 2#
ZoomAll
'连接点P5,P6
Dim line4 As AcadLine
Dim H6(0 To 1) As Double
'定义直线的起点与终点的二维坐标
P5(0) = db2 * (cosη + η * sinη) / 2#: P3(1) = db2 * (sinη - η * cosη) / 2#
P6(0) = db2 * (cosα + α * sinα) / 2#: P4(1) = db2 * (sinα - α * cosα) / 2#
ZoomAll
λ = π / 2 * z1
γ = Atn((db2 * (sinθ - θ * cosθ) / 2) / (db2 * (cosθ + θ * sinθ) / 2))
δ = λ + γ
'连接点P6,P7
Dim line5 As AcadLine
Dim H7(0 To 1) As Double
'定义直线的起点与终点的二维坐标
P7(0) = da2 * cosδ / 2: P7(1) = da2 * sinδ / 2
ZoomAll
Dim mirrorH1(0 To 1) As Double
Dim mirrorH2(0 To 2) As Double
mirrorPt2(0) = da2 * cosδ / 2#: mirrorPt2(1) = da2 * sinδ / 2
'镜像P1到P7的连线
Dim mirrorline As AcadLine
Set mirrorline = lineObj.Mirror(mirrorPt1, morrorPt2)
'阵列轮齿齿廓
Dim box2 As AcadSolid
Dim center1(0 To 1) As Double
Dim taperAngle2 As Double
taperAngle = 0
center1(0) = 0#: center1(1) = 0#
Set box2 = Userfrom1.ActiceDocument.ModelSpace.AddBox_(center, m / 2, 4 * m)
Dim retObj1 As Variant
retObj = box2.ArrayPolar(31, 2 * Pi, center1)
    retObj(I).Rotate center1, centerpoint, 3.14 / 2
    retObj(I).Update
Next I
'齿廓形成面域
Dim box2Obj As AcadEntity
Dim regionObj1 As Variant
regionObj = AcadApp.ActiveDocument.ModelSpace.AddRegion(box2)
'定义拉伸
Dim height1 As Double
Dim taper1Angle As Double
height = 64
taperAngle = -14.032
'创建面域拉伸实体
Dim solidObj2 As Acad3DSolid
Set solidObj2 = AcadApp.ActiveDocument.ModelSpace.AddExtrudedsolid_(regionObj, height, taperAngle)
End Sub
Private Sub CommandButton2_Click()
End
End Sub
该贴已经同步到 爱鑫怡爱生活的微博
发表于 2015-1-24 19:20:58 | 显示全部楼层
你把vba文件发上来,不然窗体中哪么控件,添加也很麻烦!
这么多代码,不调试很难知道哪错了
 楼主| 发表于 2015-1-25 14:19:47 | 显示全部楼层
这么多代码,不调试很难知道哪错了
附件已上,今天又修改了一下。感觉还是很多不对的地方,求指教,谢谢了
发表于 2015-1-25 14:57:33 | 显示全部楼层
楼主,几点建议
1、开明白vb语法中的数据类型,z1 = Me.TextBox7,z1得到的是字符串,不能进行数学运算,
改为z1 = Val(Me.TextBox7),这样的代码很多!
2、ε = (((df2) ^ 2 - (db2) ^ 2) ^ -2) / db2,这么多括号是干吗的?你要搞明白vb的运算优先级!这完全可能改为:ε = Sqr(df1 ^ 2 - db1 ^ 2) / db1
3、ε = Sqr(df1 ^ 2 - db1 ^ 2) / db1,既然要开平方,必须保证df1 ^ 2 - db1 ^ 2是正数!你给你例子得出结果是负数!
4、Dim p1(0 To 1) As Double
Call ThisDrawing.ModelSpace.AddLine(p1, P2)
vba帮助内容
RetVal = object.AddLine(StartPoint, EndPoint)
ModelSpace 集合, PaperSpace 集合, Block
使用该方法的对象。
StartPoint
Variant[变体] (三元素双精度数组); 仅用于输入
指定直线起点的三维WCS坐标。
EndPoint
指定直线终点的三维WCS坐标。
StartPoint,EndPoint都是三维点,你定义成了二维点。。
5、Public AcadApp As AcadApplication '定义了AcadApp 对象,但是从来没有对它进行实例化,也就是AcadApp 没有指向一个真正的对象,而后面直接用:
AcadApp.ActiveDocument.CloseAcadApp.Documents.Add
当然出错了!
这里可以用:Set AcadApp = ThisDrawing.Application 实例化
后面的没细看,你还是改改吧,尤其是vb的基础,一定要弄明白,还有一些编码的规则也学学,如变量的明确定义,变量的命令规则等
 楼主| 发表于 2015-1-26 11:25:39 | 显示全部楼层
zzyong00 发表于 2015-1-25 14:57
楼主,几点建议
感谢大神悉心指导,做课程设计太赶了,没那么多时间看书,慢慢的才了解一点点了。
非常感谢!
 楼主| 发表于 2015-1-26 11:37:24 | 显示全部楼层
楼主,几点建议
大神,能够留个QQ吗?还有很多想要请教你,麻烦你了。
我有工作家庭,不可能实时给你解答问题,有问题还是在论坛交流吧  发表于 2015-1-26 15:57
GMT+8, 2025-5-25 00:22 , Processed in 0.196086 second(s), 29 queries , Gzip On.
