查看: 2087|回复: 7
[提问] 快速选择相同半径的圆
发表于 2015-1-26 20:10:51 | 显示全部楼层 |阅读模式
因PROE导过来的2D图,经常在CAD中进行编辑。有时使用“快速先择”命令,也无法筛选出相同大小的圆,可能是导过的尺寸有很小的偏差。本人糊整了一个快速选择相同圆的LISP,但因能力有限无法完成它。请哪位大虾帮忙改进下!!!
发表于 2015-1-26 21:25:04 | 显示全部楼层
  1. (DEFUN C:qc (/ COUNTOR SELECTION DIMSE DIMDE ENTGRP COUNT ENTNAME ENT)
  2.   (COMMAND "_.UNDO" "M")
  3.   (SETQ COUNTOR 0)
  4.   (PRINC "\n批量选取圆!")
  5.   (SETQ ENT (ENTSEL "\n选择参照圆:"))
  6.   (SETQ ENT (ENTGET (CAR ENT)))
  7.   (SETQ DIMSE (CDR (ASSOC 40 ENT)))
  8. ;  (INITGET "RADIU,R DIAMETER,D ")
  9. ;  (SETQ SELECTION (GETKWORD "\n孔径匹配模式(半径或直径)(R/D)RADIU?:"))
  10.   (PROMPT "\n请选择区域:")
  11.   (SETQ ENTGRP (SSGET '((0 . "CIRCLE"))))
  12.   (SETQ COUNT 0)
  13.   (REPEAT (SSLENGTH ENTGRP)
  14.     (SETQ ENTNAME (SSNAME ENTGRP COUNT))
  15.     (SETQ ENT (ENTGET ENTNAME))
  16.     (IF (EQUAL (CDR (ASSOC 40 ENT)) DIMSE 0.00005)  ;孔径匹配,精度0.00001
  17.     (PROGN
  18.       (ENTMOD (SUBST (CONS 40 DIMSE) (ASSOC 40 ENT) ENT));更改找到的圆
  19.       (SSSETFIRST NIL ENTNAME)     ;选中找到的圆
  20.       (SETQ COUNTOR (1+ COUNTOR))  ;计数器
  21.     ))
  22.     (SETQ COUNT (1+ COUNT))
  23.   )
  24.   (PRINC "\n共计圆数量")(PRINC COUNTOR) (PRINC "!!!")
  25.   (PRINC "     -------OK-------")
  26.   (PRINC)
  27. )
复制代码
发表于 2015-1-26 21:41:39 | 显示全部楼层
  1. (defun c:tt (/ sel as-40 get len add nn as)
  2.   (and (setq sel (entsel "\n点取参照圆:"))
  3.   (progn
  4.   (setq as-40 (cdr (assoc 40 (entget (car sel)))))
  5.   (princ (strcat "\n参照圆直径=" (rtos (* as-40 2) 2 2)))
  6.   (setq get (ssget '((0 . "CIRCLE"))))
  7.   (setq len (sslength get))
  8.   (setq add (ssadd))
  9.   (repeat len
  10.     (setq nn (ssname get (setq len (1- len))))
  11.     (setq as (cdr (assoc 40 (entget nn))))
  12.     (if (equal as-40 as 0.01) (ssadd nn add))
  13.     );repeat
  14.   (if add (sssetfirst nil add))
  15.   )
  16.        )
  17.   (princ)
  18.   )
发表于 2015-1-26 22:03:12 | 显示全部楼层
我一般用小菜选择易
发表于 2015-1-28 16:52:17 | 显示全部楼层
琴剑江山_10184 发表于 2015-1-26 21:41
不能直接输入直径??
发表于 2015-1-28 17:13:39 | 显示全部楼层
ysq101 发表于 2015-1-28 16:52
不能直接输入直径??
自己改改就行了
发表于 2015-1-28 17:19:07 | 显示全部楼层
不能直接输入直径??
  (setq sel (/ (getdist "\n输入直径:") 2))
  (princ (strcat "\n过滤直径=" (rtos  (* sel 2) 2 2)))
  (setq add (ssadd))
  (repeat len
    (if (equal sel as 0.01) (ssadd nn add))
    );repeat
发表于 2015-2-3 16:37:53 | 显示全部楼层
  1. (defun c:tt(/ sel funz ss)
  2.   (setq sel (/ (getdist "\n输入直径:") 2))
  3.   (setq funz (getreal "容差范围:"))
  4.   (if(setq ss(ssget(list'(0 . "CIRCLE")'(-4 . "<and")'(-4 . ">=")(cons 40 (- sel funz))'(-4 . "<=")(cons 40 (+ sel funz))'(-4 . "and>"))))
  5.     (sssetfirst nil ss))
  6.   ss)
GMT+8, 2025-5-23 09:11 , Processed in 0.206059 second(s), 27 queries , Gzip On.
