查看: 7839|回复: 23
[源码] 分享一个dwg图纸合并程序
发表于 2015-2-6 16:11:15 | 显示全部楼层 |阅读模式
(defun c:hb()  ;插图到一起
  (setvar "CMDECHO" 0)
  (setq pf (getfiled "指定原文件路径中的一个图形文件:>" "*" "dwg" 8))
  (setq path (vl-filename-directory pf))
  (setq path (strcat path "\\"))
  (setq aa (vl-directory-files path "*.dwg" 1))
  (setq n (length aa))
  (setq i 0)
  (setq nn 0)
  (setq pp (nth i aa))
  (initget "1 2")
  (prompt "请输入图幅大小,1为A3,2为A4...\n")
  (setq opt (getkword"\n 1:A3图幅 /2:A4图幅 "))
     (cond
      ((= opt "1") (sub1))
      ((= opt "2") (sub2))
  (prompt "程序执行完毕!!!\n")
(defun sub1()
  (prompt "\n")
  (prompt "程序正在按块插入图幅,请等待...\n")
  (while (/= pp nil)
            (setq i (+ i 1))
           (setq pp (strcat path pp))
            (setq nn (+ nn 1))
                     (cond
                  ((=(rem nn 2)1) (command "insert" pp "@500,297" "1" "1" ""))                ;x,y均为相对坐标;比例1:1,不旋转;除于2余数为1,是第奇数张
                  (t (command "insert" pp "@0,-297" "1" "1" ""))                                ;x,y均为相对坐标        余数不为1,是第偶数张
          (princ (strcat "第" (itoa nn) "幅" "图号为" pp " \r"))
           (command "zoom" "e" "zoom" "0.8x")
(defun sub2()
  (prompt "\n")
  (while (/= pp nil)
            (setq i (+ i 1))
            (setq nn (+ nn 1))
                     (cond
                  ((=(rem nn 2)1) (command "insert" pp "@297,210" "1" "1" ""))                ;x,y均为相对坐标;比例1:1,不旋转;除于4余数为1,是第1张
                 (t (command "insert" pp "@0,-210" "1" "1" ""))
发表于 2025-2-22 10:00:26 | 显示全部楼层
在您的代码基础上修改了一下,不再指定A3、A4图幅,而是直接设置图纸尺寸,图纸布置顺序从左到右,再到下一排,再从左到右。
  1. ; 将多张相同尺寸的图纸插入到一张dwg图纸中
  2. (defun c:hb()
  3.   (setvar "CMDECHO" 0)
  4.   (setq pf (getfiled "指定原文件路径中的一个图形文件:>" "*" "dwg" 8))
  5.   (setq path (vl-filename-directory pf))
  6.   (setq path (strcat path "\"))
  7.   (setq aa (vl-directory-files path "*.dwg" 1))
  8.   (setq n (length aa))
  9.   ; 不超过25张图时,每行5张;超过25张图,则每行10张
  10.   (setq a1 (cond ((<= n 25) 5) (t 10)))
  11.   (setq i 0)
  12.   (setq pp (nth i aa))
  13.   (setq Lx (getint "\n请输入图纸在X轴方向尺寸(mm):"))
  14.   (setq Ly (getint "\n请输入图纸在Y轴方向尺寸(mm):"))
  15.   (sub1 Lx Ly)
  16.   (prompt "程序执行完毕!!!\n")
  17.   (princ)
  18. )
  19. (defun sub1(Lx Ly / p1)
  20.   (while (/= pp nil)
  21.     (setq p1 (list (* (rem i a1) (+ Lx 100)) (* (fix (/ i a1)) (+ Ly 100) -1)))
  22.     (setq pp (strcat path pp))
  23.   (setq i (+ i 1))
  24.     (command "insert" pp p1 "1" "1" "")
  25.     (setq pp (nth i aa))
  26.     (command "zoom" "e" "zoom" "0.8x")
  27.   )
  28. )
发表于 2018-4-27 19:03:54 | 显示全部楼层
合并成块的 还是不错的,如果能加上左右距离设置项更加好了
发表于 2020-7-11 22:40:15 | 显示全部楼层
都重叠在一起了啊,能否改善为合并后依次排开的啊
发表于 2015-2-7 07:58:43 | 显示全部楼层
不错[em0]
 楼主| 发表于 2015-2-7 13:17:03 | 显示全部楼层
这是我自己改的,感觉用的不错,偶尔有点错位
发表于 2015-5-11 13:19:18 | 显示全部楼层
万分感谢,我自己改了一下,很好用。谢谢分享。
发表于 2016-2-18 11:10:25 | 显示全部楼层
楼上能否把改后的上传一下
发表于 2016-3-15 16:42:12 来自手机 | 显示全部楼层
好像不错,电脑下载试试
发表于 2018-4-28 08:46:26 | 显示全部楼层
拿来试用一下
发表于 2018-5-2 10:18:47 | 显示全部楼层
学习下 记号
发表于 2018-5-2 13:00:23 | 显示全部楼层
请教,图框不是标准的该怎样修改代码?
GMT+8, 2025-4-21 18:06 , Processed in 0.250502 second(s), 29 queries , Gzip On.
