查看: 2633|回复: 4
[已解答] 请教 数字+字母组合的文本排序 问题
发表于 2015-2-9 14:22:11 | 显示全部楼层 |阅读模式
我的list 的数据是这样的
l_nnt '("26A" "25" "26B"  "26+"  "22" "3" "30" "29" "2" "2+" "2A" "2B" "1A" "1"  )
程序如下
(defun c:dd3()
  (vl-load-com)
  (setq l_nnt '("26A" "25" "26B"  "26+"  "22" "3" "30" "29" "2" "2+" "2A" "2B" "1A" "1" ))
  (vl-sort l_nnt (function (lambda (e1 e2)(< e1 e2))) )
但是因为 超过10以后  数据就会变成
类似  ("1" "1A" "2" "2+" "22" "25" "26+" "26A" "26B" "29" "2A" "2B" "3" "30")这个样子的。。没法做成顺序排列。。
而需要的是("1" "1A" "2" "2+" "2A" "2B" "3" "22" "25" "26+" "26A" "26B" "29""30")这样的排序
求大神解决
本帖被以下淘专辑推荐:
发表于 2015-2-9 14:37:39 | 显示全部楼层
老迈给我搞了,大体是文字长度,和acad sort吧,忘了
发表于 2015-2-9 14:42:43 | 显示全部楼层
(vl-sort l '(lambda (a b) (if (equal (atof a) (atof b) 1e-6) (< a b) (< (atof a) (atof b)))))
 楼主| 发表于 2015-2-9 14:50:21 | 显示全部楼层
感谢G版!!
发表于 2015-2-11 12:07:39 | 显示全部楼层
  1. (setq l_nnt (acad_strlsort '("26A" "25" "26B"  "26+"  "22" "3" "30" "29" "2" "2+" "2A" "2B" "1A" "1" )))
GMT+8, 2025-11-26 10:01 , Processed in 0.186967 second(s), 31 queries , Gzip On.
