查看: 1003|回复: 0
[源码] 按标注比例画矩形的程序
发表于 2015-2-13 12:13:20 | 显示全部楼层 |阅读模式
(defun C:jx(/ pt1 pt2 dimlfac)
(setq old_OS (getvar "OSMODE")) ;;保存系统变量设置
(setvar "OSMODE" 0)                    ; 关闭捕捉
(setq dimlfac (getvar "DIMLFAC"))
(setq pt1 (getpoint "\nFirst point:"))
(setq pt2 (getpoint pt1 "\nSecond point @") pt2 (mapcar '+ pt1 pt2))
(setq x (/(-(car pt2)(car pt1))dimlfac)
      y (/(-(cadr pt2)(cadr pt1))dimlfac))
(setq pt2 (list (+ (car pt1)x)(+ (cadr pt1) y)))
    (command "rectang" pt1 pt2 )
(setvar "OSMODE" old_OS)  ;;恢复系统变量设置
  (princ)(princ)
这是一个按标注比例画矩形的程序,请高手改为先定位矩形的中心点,然后输入矩形的长,高,再按标注比例画出矩形
GMT+8, 2025-5-23 10:25 , Processed in 0.178723 second(s), 29 queries , Gzip On.
