查看: 1516|回复: 4
[源码] 批量插入参照
发表于 2015-2-16 16:33:36 | 显示全部楼层 |阅读模式
(defun function_INSERT_XREF ()
  (setq filename (getfiled "选择一个文件" "*" "dwg" 16))
  (setq path (strcat (vl-filename-directory filename) "\\"))
  (setq list_filenames (vl-directory-files path "*.dwg" 1))
  (setq i 0)
  (setq p1 nil)
  (setq n (length list_filenames))
  (setq `distance (getreal "\n输入插入间距:"))
  (repeat n
          (command "-xref" "a" (strcat path (nth i list_filenames)) (if (not p1) (setq p1 '(0 0 0)) (setq p1 (polar p1 (/ pi 2) (* 1 `distance)))) 1 1 0)
          (princ (strcat "插入参照 " (nth i list_filenames) "\r"))
          (setq i (+ i 1))
  (command "zoom" "e" "zoom" "0.8x")
发表于 2015-2-16 22:58:52 | 显示全部楼层
感谢 dshshi 分享程序!
发表于 2024-6-4 16:42:58 | 显示全部楼层
请问下 这个命令怎能设置?
发表于 2024-11-14 09:03:47 | 显示全部楼层
如果增加个全选或部分选功能更完美,文件夹里的参照可能会分不同楼层的,全参照进来还要拆分。
发表于 2024-11-14 09:30:02 | 显示全部楼层
可以结合http://bbs.mjtd.com/thread-190849-1-1.html实现多选DWG
GMT+8, 2025-5-2 21:11 , Processed in 0.161990 second(s), 25 queries , Gzip On.
