查看: 2672|回复: 5
[已解答] 求将面域转化为封闭多段线的LISP
发表于 2015-3-23 12:32:27 | 显示全部楼层 |阅读模式
附件的文件全部为面域,求将面域转化为封闭多段线的码。
自已动手把码写了,给有需要的人。
(defun c:rtp (/ ss n k en spg)
  (setvar "cmdecho" 0)
  (setq ss (ssget "X" '((0 . "REGION"))))
  (setq        n (sslength ss)
        k 0
  (command "layer" "n" "PG" "c" "6" "PG" "s" "PG" "")
  (command "layer" "n" "PG1" "c" "7" "PG1" "s" "PG1" "")
  (command "peditaccept" 1)
  (repeat n
    (setq en (ssname ss k))
    (command "chprop" en "" "la" "PG1" "")
    (command "explode" en)
    (setq spg (ssget "X" '((8 . "PG1"))))
    (command "pedit" "m" spg "" "j" "0" "")
    (command "chprop" spg "" "la" "PG" "")
    (setq k (1+ k))
  (command "peditaccept" 0)
  (command "layer" "s" "PG" "")
  (command "purge" "la" "" "no")
  (setvar "cmdecho" 1)
炸开再pedit  发表于 2015-3-23 13:28
发表于 2015-3-30 22:25:03 | 显示全部楼层
是面域的线是散的连成多段线
发表于 2015-10-19 20:33:55 | 显示全部楼层
有什么办法不改图层和颜色啊
发表于 2019-6-11 19:56:01 | 显示全部楼层
不错的东西。。
发表于 2020-3-31 10:08:58 | 显示全部楼层
感谢,但是有点小问题,整个图里的面域全转了多段线,能不能改成选择修改呢,另外命令还会删除图层,不知道为什么!
发表于 2020-4-14 13:14:39 | 显示全部楼层
谢谢楼主,收藏个
GMT+8, 2025-5-18 07:24 , Processed in 0.165390 second(s), 26 queries , Gzip On.
