- 积分
- 8369
- 明经币
- 个
- 注册时间
- 2013-8-9
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
 - using System;
- using System.Collections.Generic;
- using System.Linq;
- using System.Text;
- using Autodesk.AutoCAD.DatabaseServices;
- using Autodesk.AutoCAD.Geometry;
- using Autodesk.AutoCAD.EditorInput;
- using Autodesk.AutoCAD.Colors;
- using Autodesk.AutoCAD.Runtime;
- using Autodesk.AutoCAD.ApplicationServices;
- using System.ComponentModel;
- using System.Data;
- using System.Data.OleDb;
- using System.Text.RegularExpressions;
- using System.Collections;
- namespace YFBZ
- public class Class1
- const int WM_RBUTTONDOWN = 516;
- int flag = 0;
- private void Application_PreTranslateMessage(object sender, PreTranslateMessageEventArgs e)
- if (e.Message.message == WM_RBUTTONDOWN)
- flag = 1;
- [CommandMethod("yfzj")]
- public void yfbzj()
- Database db = HostApplicationServices.WorkingDatabase;
- Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
- Editor ed = doc.Editor;
- handle01:
- PromptEntityOptions options = new PromptEntityOptions(" \n请选择圆弧");
- options.SetRejectMessage("\n所选择实体不是圆弧,请重新选择");
- options.AddAllowedClass(typeof(Arc), true);
- PromptEntityResult per = ed.GetEntity(options);
- ObjectId arced;
- if (per.Status == PromptStatus.Cancel)
- return;
- if (per.Status == PromptStatus.OK)
- arced = per.ObjectId;
- else
- return;
- using (DocumentLock acLock = doc.LockDocument())
- using (Transaction tran = db.TransactionManager.StartOpenCloseTransaction())
- Arc arc = tran.GetObject(arced, OpenMode.ForRead) as Arc;
- Point3d pt1 = arc.StartPoint;
- Point3d pt2 = arc.EndPoint;
- Point3d cen = arc.Center;
- Line line1 = new Line(cen, pt1);
- Line line2 = new Line(cen, pt2);
- line1.ColorIndex = 5;
- line2.ColorIndex = 5;
- double R = arc.Radius;
- double Length = arc.Length;
- double l = arc.GetDistanceAtParameter(Length / 2);
- Point3d pt = arc.GetPointAtDist(Length / 2);
- double cenRo = Math.Abs(arc.StartAngle - arc.EndAngle);
- double BottomRo = (Math.PI - cenRo) / 2;
- double xianLength = Math.Sqrt((pt1.X - pt2.X) * (pt1.X - pt2.X) + (pt1.Y - pt2.Y) * (pt1.Y - pt2.Y));
- double T = xianLength / 2 / Math.Sin(BottomRo);
- Point3d pt3 = xTextStyleTools.midPoint(cen, pt);
- db.AddToModelSpace(line1);
- db.AddToModelSpace(line2);
- for (; ; )
- Point3d point1 = pt3;
- DBText text1 = new DBText();
- text1.TextString="R = "+R.ToString("0.000");
- ObjectId text1Id = db.AddToModelSpace(text1);
- DBText text2 = new DBText();
- //text1.Height = 3;
- text2.TextString="K = "+ Length.ToString("0.000");
- //text2.Height = 3;
- ObjectId text2Id = db.AddToModelSpace(text2);
- DBText text3 = new DBText();
- text3.TextString = "α = "+ xTextStyleTools.DFM(cenRo);
- ObjectId text3Id = db.AddToModelSpace(text3);
- DBText text4 = new DBText();
- text4.TextString = "T = " + T.ToString("0.000");
- ObjectId text4Id = db.AddToModelSpace(text4);
- YFBZ.EntYFJip pointBz = new YFBZ.EntYFJip(text1Id, text2Id, text3Id,text4Id, point1);
- PromptResult resJip = ed.Drag(pointBz);
- if (resJip.Status == PromptStatus.Cancel)
- using (Transaction tr = db.TransactionManager.StartTransaction())
- text1 = (DBText)tr.GetObject(pointBz.m_text1, OpenMode.ForWrite);
- text1.Erase();
- text2 = (DBText)tr.GetObject(pointBz.m_text2, OpenMode.ForWrite);
- text2.Erase();
- text3 = (DBText)tr.GetObject(pointBz.m_text3, OpenMode.ForWrite);
- text3.Erase();
- text4 = (DBText)tr.GetObject(pointBz.m_text4, OpenMode.ForWrite);
- text4.Erase();
- tr.Commit();
- break;
- Autodesk.AutoCAD.ApplicationServices.Application.PreTranslateMessage += new PreTranslateMessageEventHandler(Application_PreTranslateMessage);
- if (flag == 1)
- text1.Erase();
- text2.Erase();
- text3.Erase();
- text4.Erase();
- tr.Commit();
- break;
- if (resJip.Status == PromptStatus.OK)
- db.AddToModelSpace(pointBz.GetEntity());
- flag = 0;
- goto handle01;
- flag = 0;
- tran.Commit();
- using System;
- namespace YFBZ
- public class EntYFJip : EntityJig
- private Point2d[] m_pts = new Point2d[3];
- private Point3d m_peakPt;
- private double length1, length2, length,length3,length4;
- private Point3d firstPoint;
- private Point3d m_textPt1;
- private Point3d m_textPt2;
- private Point3d m_textPt3;
- private Point3d m_textPt4;
- private Matrix3d m_mt = Matrix3d.Identity;
- public ObjectId m_text1 = ObjectId.Null;
- public ObjectId m_text2 = ObjectId.Null;
- public ObjectId m_text3 = ObjectId.Null;
- public ObjectId m_text4 = ObjectId.Null;
- public EntYFJip(ObjectId text1, ObjectId text2, ObjectId text3, ObjectId text4, Point3d Point1)
- : base(new Polyline())
- Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
- m_mt = ed.CurrentUserCoordinateSystem;
- //初始化引线
- ((Polyline)Entity).AddVertexAt(0, Point2d.Origin, 0.0, 0.0, 0.0);
- ((Polyline)Entity).AddVertexAt(1, Point2d.Origin, 0.0, 0.4, 0.4);
- ((Polyline)Entity).AddVertexAt(2, Point2d.Origin, 0.0, 0.4, 0.4);
- //参数传递
- firstPoint = Point1;
- m_text1 = text1;
- m_text2 = text2;
- m_text3 = text3;
- m_text4 = text4;
- protected override bool Update()
- //throw new NotImplementedException();
- ((Polyline)Entity).SetPointAt(0, m_pts[0]);
- ((Polyline)Entity).SetPointAt(1, m_pts[1]);
- ((Polyline)Entity).SetPointAt(2, m_pts[2]);
- ((Polyline)Entity).Normal = Vector3d.ZAxis;
- ((Polyline)Entity).Elevation = 0.0;
- //((Polyline)Entity).ConstantWidth = 0.4;
- //((Polyline)Entity).TransformBy(m_mt);
- DBText dtext1 = (DBText)tr.GetObject(m_text1, OpenMode.ForWrite);
- dtext1.Position = m_textPt1;
- dtext1.Height = 3;
- dtext1.WidthFactor = 0.8;
- dtext1.ColorIndex = 80;
- //dtext1.TextString = "X=" + m_pts[0].Y.ToString("0.000");
- length1 = Autodesk.AutoCAD.Internal.Utils.GetTextExtents(m_text1, dtext1.TextString, 2.4).X;
- DBText dtext2 = (DBText)tr.GetObject(m_text2, OpenMode.ForWrite);
- dtext2.Position = m_textPt2;
- dtext2.Height = 3;
- dtext2.WidthFactor = 0.8;
- dtext2.ColorIndex = 80;
- //dtext2.TextString = "Y=" + m_pts[0].X.ToString("0.000");
- length2 = Autodesk.AutoCAD.Internal.Utils.GetTextExtents(m_text2, dtext2.TextString, 2.4).X;
- DBText dtext3 = (DBText)tr.GetObject(m_text3, OpenMode.ForWrite);
- dtext3.Position = m_textPt3;
- dtext3.Height = 3;
- dtext3.ColorIndex = 80;
- dtext3.WidthFactor = 0.8;
- length3 = Autodesk.AutoCAD.Internal.Utils.GetTextExtents(m_text3, dtext3.TextString, 2.4).X;
- DBText dtext4 = (DBText)tr.GetObject(m_text4, OpenMode.ForWrite);
- dtext4.Position = m_textPt4;
- dtext4.Height = 3;
- dtext4.ColorIndex = 80;
- dtext4.WidthFactor = 0.8;
- length4 = Autodesk.AutoCAD.Internal.Utils.GetTextExtents(m_text4, dtext4.TextString, 2.4).X;
- if (length1 >= length2)
- length = length1;
- else
- length = length2;
- if (length < length3)
- length = length3;
- if (length < length4)
- length = length4;
- tr.Commit();
- return true;
- protected override SamplerStatus Sampler(JigPrompts prompts)
- // 定义一个点拖动交互类.
- JigPromptPointOptions optJigPoint = new JigPromptPointOptions("\n请指定下一点");
- // 设置拖拽的光标类型.
- optJigPoint.Cursor = CursorType.RubberBand;
- // 设置拖动光标基点.
- optJigPoint.BasePoint = firstPoint.TransformBy(m_mt);
- optJigPoint.UseBasePoint = true;
- // 用AcquirePoint函数得到用户输入的点.
- PromptPointResult resJigPoint = prompts.AcquirePoint(optJigPoint);
- Point3d curPt = resJigPoint.Value;
- if (resJigPoint.Status == PromptStatus.Cancel)
- return SamplerStatus.Cancel;
- if (m_peakPt != curPt)
- //保存鼠标拖曳点
- m_peakPt = curPt;
- //得到多线坐标
- if ((curPt.X - firstPoint.X >= 0 && curPt.Y - firstPoint.Y >= 0) || (curPt.X - firstPoint.X >= 0 && curPt.Y - firstPoint.Y <= 0))
- m_pts[0] = new Point2d(firstPoint.X, firstPoint.Y);
- m_pts[1] = new Point2d(m_peakPt.X, m_peakPt.Y);
- m_pts[2] = new Point2d(m_peakPt.X + length, m_peakPt.Y);
- m_textPt1 = new Point3d(m_peakPt.X + 0.5, m_peakPt.Y + 9, m_peakPt.Z);
- m_textPt2 = new Point3d(m_peakPt.X + 0.5, m_peakPt.Y + 5, m_peakPt.Z);
- m_textPt3 = new Point3d(m_peakPt.X + 0.5, m_peakPt.Y + 1, m_peakPt.Z);
- m_textPt4 = new Point3d(m_peakPt.X + 0.5, m_peakPt.Y + 13, m_peakPt.Z);
- else
- m_pts[2] = new Point2d(m_peakPt.X - length, m_peakPt.Y);
- m_textPt1 = new Point3d(m_peakPt.X - length+0.5, m_peakPt.Y + 9, m_peakPt.Z);
- m_textPt2 = new Point3d(m_peakPt.X - length+0.5, m_peakPt.Y + 5, m_peakPt.Z);
- m_textPt3 = new Point3d(m_peakPt.X - length+0.5, m_peakPt.Y + 1, m_peakPt.Z);
- m_textPt4 = new Point3d(m_peakPt.X -length + 0.5, m_peakPt.Y + 13, m_peakPt.Z);
- return SamplerStatus.OK;
- else
- return SamplerStatus.NoChange;
- public Entity GetEntity()
- return Entity;
- using System;
- namespace YFBZ
- public static class Class2
- public static ObjectId AddToModelSpace(this Database db, Entity ent)
- ObjectId entId;//用于返回添加到模型空间中的实体ObjectId
- //定义一个指向当前数据库的事务处理,以添加直线
- using (Transaction trans = db.TransactionManager.StartTransaction())
- //以读方式打开块表
- BlockTable bt = (BlockTable)trans.GetObject(db.BlockTableId, OpenMode.ForRead);
- //以写方式打开模型空间块表记录.
- BlockTableRecord btr = (BlockTableRecord)trans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
- entId = btr.AppendEntity(ent);//将图形对象的信息添加到块表记录中
- trans.AddNewlyCreatedDBObject(ent, true);//把对象添加到事务处理中
- trans.Commit();//提交事务处理
- return entId; //返回实体的ObjectId
- /// <summary>
- /// 获取与定点指定角度与距离的点
- /// </summary>
- /// <param name="pline">多段线对象</param>
- public static Point3d polarPoint(this Point3d point, double angle, double dist)
- return new Point3d(point.X + dist * Math.Cos(angle), point.Y + dist * Math.Sin(angle), point.Z);
- /// <summary>
- /// 弧度转度分秒
- /// </summary>
- /// <param name="Alpha">弧度数组</param>
- public static string DFM(double Alpha)
- string dfm;
- dfm = "0.00";
- double t = 180.0 * Alpha / 3.1415926;
- int d = (int)t;
- int m = (int)((t - d) * 60);
- int s = (int)((t - d - m / 60.0) * 3600);
- dfm = d.ToString() + "o" + m.ToString() + "\'" + s.ToString() + """;
- return dfm;
- /// <summary>
- /// 获取两点直线中点
- /// </summary>
- public static Point3d midPoint(Point3d point1, Point3d point2)
- return new Point3d((point1.X + point2.X) / 2, (point1.Y + point2.Y) / 2, (point1.Z + point2.Z) / 2);
