查看: 3046|回复: 6
[讨论] 求高手修改下批量偏移 万分感谢
发表于 2015-4-3 00:04:38 | 显示全部楼层 |阅读模式
;;批量偏移 By Gu_xl 2013.04.01
(defun c:py (/ CLOCKWISEP OFFSET KD SS N EN kd0)
  (defun CLOCKWISEP (en / lw minp MaxP lst)
    (setq lw (vlax-ename->vla-object en))
    (vla-GetBoundingBox lw 'MinP 'MaxP)
    (setq
      minp (vlax-safearray->list minp)
      MaxP (vlax-safearray->list MaxP)
      lst  (mapcar
             (function
               (lambda (x)
                 (vlax-curve-getParamAtPoint
                   lw
                   (vlax-curve-getClosestPointTo lw x)
             (list minp
                   (list (car minp) (cadr MaxP))
                   MaxP
                   (list (car MaxP) (cadr minp))
    (if (or
          (<= (car lst) (cadr lst) (caddr lst) (cadddr lst))
          (<= (cadr lst) (caddr lst) (cadddr lst) (car lst))
          (<= (caddr lst) (cadddr lst) (car lst) (cadr lst))
          (<= (cadddr lst) (car lst) (cadr lst) (caddr lst))
      t
  (initget 7 "W N S  ")
  (setq kd0 (getkword "\n[向外偏移W/向内偏移N/双向偏移S]<W>"))
  (if (= "" kd0)
    (setq kd0 "W")
  (initget 6)
  (setq offset (getreal "\n[输入偏移距离]<0.5>"))
  (if (null offset)
    (setq offset 0.5)
  (initget 7 "Y N  ")
  (setq kd (getkword "\n[删除源对象<Y>/不删除源对象<N>]<N>:"))
  (if (= kd "")
    (setq kd "N")
  (while (setq ss (ssget '((0 . "*polyline,arc,circle"))))
    (repeat (setq n (sslength ss))
      (setq en (ssname ss (setq n (1- n))))
      (cond
        ((or (= "ARC" (cdr (assoc 0 (entget en))))
             (= "CIRCLE" (cdr (assoc 0 (entget en))))
         (cond ((= kd0 "W")
                (vla-offset (vlax-ename->vla-object en) offset)
               ((= kd0 "N")
                (vla-offset (vlax-ename->vla-object en) (- offset))
               (t
        (t
         (cond ((= kd0 "W")
                (if (CLOCKWISEP en)
               ((= kd0 "N")
                (if (CLOCKWISEP en)
               (t
      (if (= kd "Y")
        (entdel en)
求解决:望高手帮忙稍作修改添加语言,在上面代码偏移距离完成后插入这样一句------(在原图层偏移过后的线型可以统一产生用蓝色或者绿色区分表示开来,如果遇到不能偏移个体的情况下,自动用红色线型标记出,)以便检查。
 楼主| 发表于 2015-4-3 07:53:48 | 显示全部楼层
顶大师出现
发表于 2019-5-26 20:11:42 | 显示全部楼层
做个记号,顶一大师
发表于 2022-4-21 20:10:59 | 显示全部楼层
666 等大师修改
发表于 2022-10-13 15:52:20 | 显示全部楼层
等大师出现
发表于 2022-10-14 10:26:03 来自手机 | 显示全部楼层
正需要这个,等分享
发表于 2023-11-1 19:45:19 | 显示全部楼层
循环到一个小于偏移值时 之后的就不能偏移了  偏移结束
GMT+8, 2025-5-11 14:07 , Processed in 0.180392 second(s), 25 queries , Gzip On.
