查看: 1007|回复: 0
[提问] 求大师帮忙添加个句子-----批量偏移
发表于 2015-4-3 09:02:40 | 显示全部楼层 |阅读模式
;;批量偏移 By Gu_xl 2013.04.01
(defun c:py (/ CLOCKWISEP OFFSET KD SS N EN kd0)
  (defun CLOCKWISEP (en / lw minp MaxP lst)
    (setq lw (vlax-ename->vla-object en))
    (vla-GetBoundingBox lw 'MinP 'MaxP)
    (setq
      minp (vlax-safearray->list minp)
      MaxP (vlax-safearray->list MaxP)
      lst  (mapcar
             (function
               (lambda (x)
                 (vlax-curve-getParamAtPoint
                   lw
                   (vlax-curve-getClosestPointTo lw x)
             (list minp
                   (list (car minp) (cadr MaxP))
                   MaxP
                   (list (car MaxP) (cadr minp))
    (if (or
          (<= (car lst) (cadr lst) (caddr lst) (cadddr lst))
          (<= (cadr lst) (caddr lst) (cadddr lst) (car lst))
          (<= (caddr lst) (cadddr lst) (car lst) (cadr lst))
          (<= (cadddr lst) (car lst) (cadr lst) (caddr lst))
      t
  (initget 7 "W N S  ")
  (setq kd0 (getkword "\n[向外偏移W/向内偏移N/双向偏移S]<W>"))
  (if (= "" kd0)
    (setq kd0 "W")
  (initget 6)
  (setq offset (getreal "\n[输入偏移距离]<0.5>"))
  (if (null offset)
    (setq offset 0.5)
  (initget 7 "Y N  ")
  (setq kd (getkword "\n[删除源对象<Y>/不删除源对象<N>]<N>:"))
  (if (= kd "")
    (setq kd "N")
  (while (setq ss (ssget '((0 . "*polyline,arc,circle"))))
    (repeat (setq n (sslength ss))
      (setq en (ssname ss (setq n (1- n))))
      (cond
        ((or (= "ARC" (cdr (assoc 0 (entget en))))
             (= "CIRCLE" (cdr (assoc 0 (entget en))))
         (cond ((= kd0 "W")
                (vla-offset (vlax-ename->vla-object en) offset)
               ((= kd0 "N")
                (vla-offset (vlax-ename->vla-object en) (- offset))
               (t
        (t
         (cond ((= kd0 "W")
                (if (CLOCKWISEP en)
               ((= kd0 "N")
                (if (CLOCKWISEP en)
               (t
      (if (= kd "Y")
        (entdel en)
求解决:望高手帮忙稍作修改添加语言,在上面代码偏移距离完成后插入这样一句------(在原图层偏移过后的线型可以统一产生用蓝色或者绿色区分表示开来,如果遇到不能偏移个体的情况下,自动用红色线型标记出,)以便检查。
GMT+8, 2025-5-23 09:58 , Processed in 0.168179 second(s), 25 queries , Gzip On.
