- 积分
- 8369
- 明经币
- 个
- 注册时间
- 2013-8-9
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
 - [CommandMethod("WZXG")]
- public void WZG()
- Database db = HostApplicationServices.WorkingDatabase;
- Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
- Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
- PromptSelectionOptions options = new PromptSelectionOptions();
- SelectionFilter fil = new SelectionFilter(new TypedValue[] { new TypedValue(0, "*text,mtext") });
- options.MessageForAdding = "\n选择文字:";
- OpenTextStyle.ss1 = ed.GetSelection(options, fil);
- OpenTextStyle opentextstyle = new OpenTextStyle();
- Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(opentextstyle);
- public partial class OpenTextStyle : Form
- public static PromptSelectionResult ss1;
- public OpenTextStyle()
- InitializeComponent();
- private void button1_Click(object sender, EventArgs e)
- this.Hide();
- using (Transaction tr = db.TransactionManager.StartOpenCloseTransaction())
- SelectionSet ss = ss1.Value;
- if (ss1.Status != PromptStatus.OK) return;
- if (ss1.Status == PromptStatus.Cancel) return;
- ObjectIdCollection objectId1 = new ObjectIdCollection();
- ObjectIdCollection objectId2 = new ObjectIdCollection();
- using (Transaction tr1 = doc.TransactionManager.StartTransaction())
- foreach (ObjectId id in ss.GetObjectIds())
- Entity entity = tr.GetObject(id, OpenMode.ForRead) as Entity;
- if (entity.GetType().Name == "DBText")
- objectId1.Add(id);
- else if (entity.GetType().Name == "MText")
- objectId2.Add(id);
- tr1.Commit();
- using (Transaction tr2 = doc.TransactionManager.StartTransaction())
- foreach (ObjectId textId in objectId1)
- DBText dText = tr2.GetObject(textId, OpenMode.ForWrite) as DBText;
- using (Transaction tr3 = db.TransactionManager.StartTransaction())
- TextStyleTable st = (TextStyleTable)db.TextStyleTableId.GetObject(OpenMode.ForRead);
- foreach (ObjectId td in st)
- TextStyleTableRecord textR = tr.GetObject(td, OpenMode.ForRead) as TextStyleTableRecord;
- if (textR.Name == this.comboBox1.SelectedItem.ToString())
- dText.TextStyleId = td;
- tr3.Commit();
- dText.Height = Convert.ToDouble(this.textBox1.Text.ToString());
- dText.WidthFactor = Convert.ToDouble(this.textBox2.Text.ToString());
- dText.DowngradeOpen();
- foreach (ObjectId textId1 in objectId2)
- MText Mtext = tr2.GetObject(textId1, OpenMode.ForWrite) as MText;
- using (Transaction tr4 = db.TransactionManager.StartTransaction())
- TextStyleTableRecord textR = tr.GetObject(td, OpenMode.ForWrite) as TextStyleTableRecord;
- textR.XScale = Convert.ToDouble(this.textBox2.Text.ToString());
- Mtext.TextStyleId = td;
- textR.DowngradeOpen();
- tr4.Commit();
- Mtext.TextHeight = Convert.ToDouble(this.textBox1.Text.ToString());
- Mtext.DowngradeOpen();
- tr2.Commit();
- tr.Commit();
- this.Close();
- private void comboBox1_SelectedIndexChanged(object sender, EventArgs e)
- private void OpenTextStyle_Load(object sender, EventArgs e)
- List<string> comString = new List<string>();
- using (Transaction tr = db.TransactionManager.StartTransaction())
- foreach (ObjectId tId in st)
- TextStyleTableRecord textR = tr.GetObject(tId, OpenMode.ForRead) as TextStyleTableRecord;
- comString.Add(textR.Name);
- this.comboBox1.DataSource = comString;
- tr.Commit();
- private void button2_Click(object sender, EventArgs e)
- this.Close();
