查看: 813|回复: 1
[讨论] 请问如何实现图中的效果
发表于 2015-4-13 09:56:27 | 显示全部楼层 |阅读模式
烦请高手指点迷津,如何修改以下程序,实现图片中的效果。
(defun c:TT()
  (VL-LOAD-COM)
  (setq        AcadObject   (vlax-get-acad-object)
        AcadDocument (vla-get-ActiveDocument Acadobject)
        mSpace             (vla-get-ModelSpace Acaddocument)
  ;;输入总间距
  (setq        prefix1        (vla-GetString
                  (vla-get-Utility AcadDocument)
                  :vlax-false
                  "请输入总间距:"
(setq        prefix2        (vla-GetString
                  :vlax-false
                  "请输入孔间距:"
  ;;选择一个标注
  (setq dimObj1 (car (entsel)))
  (setq dimObj (vlax-ename->vla-object dimObj1))
(setq prefix3 (\ prefix1 prefix2))
(setq prefix (strcat prefix3 "×" prefix2  "(=" ))
(setq  suffix ")" )
  ;;添加前缀
  (vla-put-TextPrefix dimObj prefix)
  ;;添加后缀
  (vla-put-TextSuffix dimObj suffix)
发表于 2015-8-31 16:25:11 | 显示全部楼层
是不是要改成这样:
  1. (defun c:TT ()
  2.   (VL-LOAD-COM)
  3.   ;;输入总间距
  4.   (setq prefix1 (getreal "\n请输入总间距:"))
  5.   (setq prefix2 (getreal "\n请输入孔间距:"))
  6.   ;;选择一个标注
  7.   (setq dimObj1 (car (entsel)))
  8.   (setq dimObj (vlax-ename->vla-object dimObj1))
  9.   (setq prefix3 (/ prefix1 prefix2))
  10.   (setq prefix (strcat (rtos prefix3 2 0) "×" (rtos prefix2 2 0) "(="))
  11.   (setq suffix ")")
  12.   ;;添加前缀
  13.   (vla-put-TextPrefix dimObj prefix)
  14.   ;;添加后缀
  15.   (vla-put-TextSuffix dimObj suffix)
  16.   (princ)
  17. )
GMT+8, 2025-5-21 10:04 , Processed in 0.199617 second(s), 30 queries , Gzip On.
