查看: 901|回复: 3
[讨论] lisp如何实现先选中图元再输入命令进行操作
发表于 2015-4-14 12:17:47 | 显示全部楼层 |阅读模式
如题,就像cad自带的Move命令一样,先选中图元再输入Move命令,然后就可以直接移动了。
求思路。
发表于 2015-4-14 13:34:59 | 显示全部楼层
ssgetfirst Function
Determines which objects are selected and gripped
(ssgetfirst)
Returns a list of two selection sets similar to those passed to sssetfirst. The first element in the list is a selection set of entities that are gripped but not selected. The second element is a selection set of entities that are both gripped and selected. Either (or both) elements of the list can be nil.
Note  Only entities from the current drawing's model space and paper space, not nongraphical objects or entities in other block definitions, can be analyzed by this function.
See Also
The ssget and sssetfirst functions.
发表于 2015-4-14 13:56:51 | 显示全部楼层
ssget 放在defun里面第一句,先取得选择集再执行其它操作
 楼主| 发表于 2015-4-14 15:00:16 | 显示全部楼层
Andyhon 发表于 2015-4-14 13:34
ssgetfirst Function
了解啦,(ssgetfirst) 判断一下就ok啦!
GMT+8, 2025-5-23 10:24 , Processed in 0.191781 second(s), 30 queries , Gzip On.
