查看: 1190|回复: 0
[测绘] 为什么提取的高程点数据不对啊
发表于 2015-4-18 19:53:41 | 显示全部楼层 |阅读模式
;;;*****导出多段线顶点坐标 程序开始*****
(defun c:t1 (/ entnam dwg)
  (setvar "cmdecho" 0)
   (setq ffn (getfiled "文件保存为" "" "dat" 1))
  (setq ff (open ffn "w"))
  (close ff)
  (princ "\n选取要导出标高的多段线:")
  (setq ss (ssget '((0 . "POLYLINE,LWPOLYLINE"))))
  (princ "\n选取要导出标高的多段线顶点处的块参照:")
  (setq ss_block (ssget '((0 . "INSERT") (2 . "GC200"))))
  (setq m 0
i 0
list_block
  nil
  (setvar "pdmode" 35)
  (vl-load-com)
  (repeat (sslength ss_block)
    (setq ent_block  (ssname ss_block m)
   data_block (entget ent_block)
   pt_block   (cdr (assoc 10 data_block))
   list_block (cons pt_block list_block)
    (setq m (1+ m))
  (setq ff (open ffn "a"))
    (close ff)
  (repeat (sslength ss)
    (setq entnam  (ssname ss i)
   obj   (vlax-ename->vla-object entnam)
   pt_list nil
   list_ok nil
    (setq j -1)
    (while (setq pp (vlax-curve-getpointatparam obj (setq j (1+ j))))
      (setq pt_list (cons (list (+ j 1) pp) pt_list))
    (if
nil
(vl-position
   "nil"
   (mapcar '(lambda (a b) (equal a b 0.01))
    (mapcar '(lambda (x) (cdr (reverse (cadr x)))) pt_list)
    (mapcar '(lambda (x) (cdr (reverse x))) list_block)
       (setq list_ok
       (reverse
  (mapcar
    '(lambda (x) (reverse x))
    (mapcar
      'cons
      (mapcar '(lambda (x) (car (reverse x))) list_block)
      (mapcar
        '(lambda (x) (cdr (reverse (cons (car x) (cadr x)))))
        pt_list
        (princ (strcat (itoa (car x))
         (rtos (cadr x) 2 3)
         (rtos (caddr x) 2 3)
         (rtos (last x) 2 3)
         "\n"
        ff
     list_ok
    (setq i (1+ i))
     (princ "\n" ff)
    (close ff)
  (princ (strcat "\n文件已保存至:" ffn))
;;;*****导出多段线顶点坐标 程序结束*****
GMT+8, 2025-5-22 08:26 , Processed in 0.180567 second(s), 25 queries , Gzip On.
