查看: 24163|回复: 85
[源码] 批次依“模型”内图框于“配置”产生视口(可旋转)
发表于 2015-4-19 07:07:00 | 显示全部楼层 |阅读模式
代码的主要构思是从下面的三个部分组成的,里面的副程式请自己到黄大侠、高飞版主的个别帖子找!
偶而花花时间去翻帖子也是不错的。
最小包围核代码是 自贡黄明儒:http://bbs.mjtd.com/thread-107647-1-1.html
                         及 highflybir:http://bbs.mjtd.com/thread-99926-1-1.html
视埠旋转的想法是 自贡黄明儒:http://bbs.mjtd.com/thread-111691-1-1.html
主架构是依照http://cadtips.cadalyst.com/viewports/viewport-layouts修改的
下面是其他拼拼凑凑的代码如果不合用就自己再改改吧!
  1. ;;最小包围核代码是 自贡黄明儒:http://bbs.mjtd.com/thread-107647-1-1.html]http://bbs.mjtd.com/thread-107647-1-1.html
  2. ;;                            及 highflybir:http://bbs.mjtd.com/thread-99926-1-1.html]http://bbs.mjtd.com/thread-99926-1-1.html
  3. ;;视埠旋转的想法是 自贡黄明儒:http://bbs.mjtd.com/thread-111691-1-1.html]http://bbs.mjtd.com/thread-111691-1-1.html
  4. (princ
  5.   "\n===================================================="
  6. )
  7. (princ "\n命令:rv")
  8. (princ "\n说明:批次依“模型”内图框于“配置”产生视埠")
  9. (princ "\n说明:可适用于有旋转角的图框")
  10. (princ "\nby Atsai 2015.03.12")
  11. (princ
  12.   "\n===================================================="
  13. )
  14. (defun c:rv (/ cp cl cs vpl os vplyes l0 svpc ptlst ssvp)
  15.   (vl-load-com)
  16.   (setvar "cmdecho" 0) ; Turn off command line echoing
  17.   (setq cp (getvar "ctab")) ; Store current tab name
  18.   (setq cl (getvar "clayer")) ; Store current layer name
  19.   (setq cs (getvar "osmode")) ; Store current osnap mode
  20.   (setq vpl "视埠") ; ==>> Assume using Viewport layer for viewport frames, change code value here if needed <<==
  21.   (setq os (getvar "osmode")) ;读取锁点原设定
  22.   (setvar "osmode" 0)
  23.   (setq        nselect
  24.          (getstring
  25.            "\n选择排序方式,(1)自选顺序(2)左->右(3)右->左(4)上->下(5)下->上:预设(1)"
  26.          )
  27.   )
  28.   (if (= nselect "")
  29.     (setq nselect "1")
  30.   )
  31.   (if (/= cp "Model") ; Must be started from a layout tab to establish destination, quit quietly if on Model tab
  32.     (progn
  33.       (setq vplyes 0) ; Assume viewport doesn't exist
  34.       (setq l0 (tblnext "LAYER" 1)) ; Get past 0 layer in layer list
  35.       (while (setq layers (tblnext "LAYER"))
  36.         ;; Loop through layer list collection
  37.         (setq ln (cdr (assoc 2 layers))) ; Extract layer name from list
  38.         (if (= (strcase ln) (strcase vpl))
  39.           (setq vplyes 1)
  40.         ) ; Check if viewport layer exists
  41.       )
  42.       (if (= vplyes 0)
  43.         (command "layer" "NEW" vpl "COLOR" "RED" vpl "")
  44.       ) ; Make viewport layer and assign color to magenta if doesn't exist
  45.       (setvar "clayer" vpl) ; Change to viewport layer
  46.       (command "layer"
  47.                "ON"
  48.                (strcat "0," vpl)
  49.                "UNLOCK"
  50.                (strcat "0," vpl)
  51.                ""
  52.       ) ; Turn on and unlock viewport and 0 layer
  53.       (command "zoom" "ALL") ; View entire layout tab
  54.       (setvar "ctab" "Model") ; Activate Model tab
  55.       (command "zoom" "E") ; View entire Model Space area
  56.       (setq ss nil)
  57.       (if (setq ss (ssget '((0 . "INSERT"))))
  58.         (progn
  59.           (setq        l (sslength ss)
  60.                 i 0
  61.           )
  62.           (setq ent_lst nil)
  63.           (repeat (sslength ss)
  64.             (setq ent_lst (append ent_lst (list (ssname ss i)))
  65.                   i          (1+ i)
  66.             )
  67.           )
  68.           (princ "\n") ; Clean up command line
  69.           (setvar "ctab" cp) ; Return to layout tab program was started from
  70.           (command "pspace") ; Switch to Paper Space of layout tab
  71.           (setq ptlst nil)
  72.           (setq ptlst (HH:Ent4pt (nth 0 ent_lst) T))
  73.           (setq vpc1 (nth 0 ptlst))
  74.           (setq vpc2 (nth 1 ptlst))
  75.           (setq vpc3 (nth 2 ptlst))
  76.           (setq vpc4 (nth 3 ptlst))
  77.           (setq sf 1.0)
  78.           (setq vpyd (* sf (distance vpc2 vpc3)))
  79.           (defun viewpnts (/ a b c d x)
  80.             (setq b (getvar "viewsize")
  81.                   c (car (getvar "screensize"))
  82.                   d (cadr (getvar "screensize"))
  83.                   a (* b (/ c d))
  84.                   x (setq x (getvar "viewctr"))
  85.                   x (trans x 1 2)
  86.                   c (list (- (car x) (/ a 2.0)) (- (cadr x) (/ b 2.0)) 0.0)
  87.                   d (list (+ (car x) (/ a 2.0)) (+ (cadr x) (/ b 2.0)) 0.0)
  88.                   c (trans c 2 1)
  89.                   d (trans d 2 1)
  90.             )
  91.             (list c d)
  92.           )
  93.           (setq c (nth 0 (viewpnts)))
  94.           (setq d (nth 1 (viewpnts)))
  95.           (setq mvpc (list (/ (+ (car c) (car d)) 2.0) (/ (+ (cadr c) (cadr d)) 2.0) 0.0))
  96.           (command "zoom" "C" mvpc (rtos (* (* 2 l) vpyd)))
  97.           (setq        svpc
  98.                  (getpoint
  99.                    "\n选择插入点:"
  100.                  )
  101.           ) ; Can't change layout tabs manually here
  102.           (cond
  103.             ((= nselect "1")
  104.              (setq ent_lst ent_lst)
  105.             )
  106.             ((= nselect "2")
  107.              (progn
  108.                ;;按X座标排序
  109.                (setq
  110.                  ent_lst (vl-sort ent_lst
  111.                                   '(lambda (e1 e2)
  112.                                      (<        (cadr (assoc 10 (entget e1)))
  113.                                         (cadr (assoc 10 (entget e2)))
  114.                                      )
  115.                                    )
  116.                          )
  117.                )
  118.                ;;按X座标排序
  119.              )
  120.             )
  121.             ((= nselect "3")
  122.              (progn
  123.                ;;按X座标排序
  124.                (setq
  125.                  ent_lst (vl-sort ent_lst
  126.                                   '(lambda (e1 e2)
  127.                                      (>        (cadr (assoc 10 (entget e1)))
  128.                                         (cadr (assoc 10 (entget e2)))
  129.                                      )
  130.                                    )
  131.                          )
  132.                )
  133.                ;;按X座标排序
  134.              )
  135.             )
  136.             ((= nselect "4")
  137.              (progn
  138.                ;;按Y座标排序
  139.                (setq
  140.                  ent_lst (vl-sort ent_lst
  141.                                   '(lambda (e1 e2)
  142.                                      (>        (caddr (assoc 10 (entget e1)))
  143.                                         (caddr (assoc 10 (entget e2)))
  144.                                      )
  145.                                    )
  146.                          )
  147.                )
  148.                ;;按Y座标排序
  149.              )
  150.             )
  151.             ((= nselect "5")
  152.              (progn
  153.                ;;按Y座标排序
  154.                (setq
  155.                  ent_lst (vl-sort ent_lst
  156.                                   '(lambda (e1 e2)
  157.                                      (<        (caddr (assoc 10 (entget e1)))
  158.                                         (caddr (assoc 10 (entget e2)))
  159.                                      )
  160.                                    )
  161.                          )
  162.                )
  163.                ;;按Y座标排序
  164.              )
  165.             )
  166.           )
  167.           (mapcar
  168.             '(lambda (ssn)
  169.                (setq ptlst nil)
  170.                (setq ptlst (HH:Ent4pt ssn T))
  171.                (setq vpc1 (nth 0 ptlst))
  172.                (setq vpc2 (nth 1 ptlst))
  173.                (setq vpc3 (nth 2 ptlst))
  174.                (setq vpc4 (nth 3 ptlst))
  175.                (setq sf 1.0)
  176.                (setq vpxd (* sf (distance vpc1 vpc2)))
  177.                ;; Determine horizontal length of selected window
  178.                (setq vpyd (* sf (distance vpc2 vpc3)))
  179.                ;; Determine vertical height of selected window
  180.                (setq
  181.                  vpc
  182.                   (list        (/ (+ (car vpc1) (car vpc3)) 2.0)
  183.                         (/ (+ (cadr vpc1) (cadr vpc3)) 2.0)
  184.                         0.0
  185.                   )
  186.                )
  187.                ;; Determine center point of selected model window
  188.                (command        "mview"
  189.                         (list (car svpc) (cadr svpc))
  190.                         (strcat "@" (rtos vpxd) "," (rtos vpyd))
  191.                )
  192.                ;; Create Paper Space viewport
  193.                (setq ssvp nil)
  194.                (setq ssvp (ssget "L"))
  195.                ;; Start selection set with last viewport frame
  196.                (command        "zoom"
  197.                         "w"
  198.                         (list (car svpc) (cadr svpc))
  199.                         (strcat "@" (rtos vpxd) "," (rtos vpyd))
  200.                )
  201.
  202.                (command "mspace")
  203.                ;; Open viewport window to Model Space
  204.                (command "ucsicon" "ON")
  205.                ;; Turn on UCS icon for viewport
  206.                (command "ucs" "Z" "non" vpc1 "non" vpc2)
  207.                (command "Plan" "")
  208.                (command "ucs" "WORLD") ; Reset UCS to WCS
  209.                (command "zoom" "C" vpc (rtos vpyd))
  210.                ;; Center view of viewport window using determined point
  211.                (command "zoom" "SCALE" (strcat (rtos sf) "XP"))
  212.                ;; Set zoom scale of viewport window
  213.                (command "vports" "LOCK" "ON" ssvp "")
  214.                ;; Lock scale and position of model in viewport
  215.                (command "pspace")
  216.                ;; Close viewport window
  217.                (setq w (distance vpc1 vpc2))
  218.                (setq svpc (polar svpc 0 (* 1.5 w)))
  219.              )
  220.             ent_lst
  221.           )
  222.         )
  223.       )
  224.     )
  225.     (princ "\n这个LISP程式只能在Layout使用!")
  226.     ;; Need to start on a layout tab so program knows where to create the new viewports
  227.   )
  228.   (command "zoom" "all")
  229.   (setvar "ctab" cp) ; Reset to stored tab name
  230.   (setvar "clayer" cl) ; Reset to stored layer name
  231.   (setvar "osmode" os) ;回复锁点原设定
  232.   (princ)
  233. )
  234. )
没有看懂,楼主能不能上传测试dwg上来?  发表于 2015-5-18 12:50
参与人数 3明经币 +3 金钱 +20 收起 理由
自贡黄明儒 + 1 很给力!
spp_wall + 1 + 20 赞一个!
USER2128 + 1 很给力!
本帖被以下淘专辑推荐:
 楼主| 发表于 2021-12-28 11:05:20 | 显示全部楼层
Aries 发表于 2021-12-27 19:11
我又来讨教问题了   请问怎么改成可以设置视口比例啊?  现在视口是1比1的比例
想改成生成视口可以选择 ...
假设出图范围是A3的,直接设画一个1:1的范围矩型,再做成基准在左下角的图块。
这时候,你要不同比例,直接在图块调整比例,再执行就可以了。
至于为何一定执着于矩形POLYLINE?如果一定要POLYLINE的范围,出完再炸掉也ok吧!
如果一定要多段线范围,又有旋转,建议直接找相关抓PLINE点的副程式取代黄大师最小包围盒的部份。
 楼主| 发表于 2021-12-24 15:31:49 | 显示全部楼层
Aries 发表于 2021-12-23 12:10
请教了海角天涯   把insert改成lwpolyline 就可以拾取多段线了
当初会用图块,是为了利用左下角点去判断方向,而且图块比例也方便设定。
你的方式改了以后,如果多段线不是水平的,就达不到所需要的范围。(因为黄大师的副程式在旋转的多段线
出来的最小包围盒会是水平的范围)。如果用多段线范围,建议直接修改取4个角点就好了。
其实就是把多段线范围,建立成一个图块,这样也方便摆位置,调角度,不是吗?
发表于 2021-12-27 19:11:51 | 显示全部楼层
你的方式改了以后,如果多段 ...
想改成生成视口可以选择设置比例
发表于 2015-4-19 09:45:14 | 显示全部楼层
no function definition: HH:ENT4PT
 楼主| 发表于 2015-4-19 11:12:51 | 显示全部楼层
帖子开头已经有说明,副程式要到黄工及高飞鸟的原帖里面找!
因为原帖是有售价的,不便在这里放上来。
发表于 2015-4-19 13:01:38 | 显示全部楼层
视埠是指 ?? 窗口 ?
发表于 2015-4-19 14:48:12 | 显示全部楼层
视埠应该是常说的视口
 楼主| 发表于 2015-4-23 20:41:57 | 显示全部楼层
lucas_3333 发表于 2015-4-19 13:01
视埠是指 ?? 窗口 ?
视埠就是视口!
发表于 2015-5-2 15:38:16 | 显示全部楼层
如果能生成到图纸空间多好呀!
发表于 2015-5-2 16:19:00 | 显示全部楼层
DEAR SIR.
NICE
 楼主| 发表于 2015-5-2 19:34:41 | 显示全部楼层
這個原本就是在配置,也就是佈局建立視口。
如果要再修成單一個配置一個視口,就要再修。
发表于 2015-5-3 07:44:14 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-6-13 06:34 , Processed in 0.243357 second(s), 39 queries , Gzip On.
