查看: 1138|回复: 1
[基础] 块的取比例大小和取块的宽度的代码函数是什么阿?
发表于 2015-4-30 09:12:49 | 显示全部楼层 |阅读模式
谢谢``````````````````````````````````````取比例和取块的宽分别是什么阿
发表于 2015-4-30 11:25:58 | 显示全部楼层
BlockReference.ScaleFactors
public Scale3d ScaleFactors;
The X, Y, and Z scaling of the block reference is applied to the entities in the referenced block table record relative to their perceived WCS coordinate axes, which may or may not be the same as the drawing’s WCS axes.
The X scale factor value is used for DXF group code 41.
The Y scale factor value is used for DXF group code 42.
The Z scale factor value is used for DXF group code 43.
GMT+8, 2025-5-25 02:26 , Processed in 0.134684 second(s), 24 queries , Gzip On.
