查看: 1192|回复: 3
[提问] ObjectDBX方式预读属性块文件的属性
发表于 2015-5-3 17:12:09 | 显示全部楼层 |阅读模式
求帮忙啊,有时候正常有时候错误
  1. (vl-load-com)
  2. ;ObjectDBX方式预读属性块文件的属性
  3. (defun c:xx()
  4.   (setq DWGNAME (getfiled "选取图档" (getvar "dwgprefix") "dwg" 2))
  5.   (setq APP (vlax-get-acad-object))
  6.   (setq DBXDOC (vla-GetInterfaceObject APP
  7.                  (if (<= (setq VERSION (atoi (getvar "acadver"))) 15)
  8.                    "ObjectDBX.AxDbDocument"
  9.                    (strcat "ObjectDBX.AxDbDocument." (itoa VERSION))
  10.                    )
  11.                  )
  12.         )
  13.   (vla-open DBXDOC DWGNAME)
  14.   (setq objs (vla-get-modelspace DBXDOC))
  15.   (vlax-for xx objs
  16.     (if (= (vla-get-ObjectName xx) "AcDbAttributeDefinition")
  17.       (setq LST (cons (cons (vla-get-TagString xx)(vla-get-TextString xx)) LST))
  18.       )
  19.     )
  20.   (vla-Close DBXDOC DWGNAME)
  21.   (vlax-release-object DBXDOC)
  22.   (vlax-release-object app)
  23.   (princ lst)
  24.   (princ)
  25.   )
 楼主| 发表于 2015-5-3 17:38:10 | 显示全部楼层
打开预读取之后就关闭不了文件了
发表于 2015-5-3 19:32:04 | 显示全部楼层
  1. (vl-load-com)
  3. (defun c:xx()
  10.                         )
  11.                 )
  12.         )
  18.                 )
  19.         )
  20.   ;(vla-Close DBXDOC DWGNAME)
  23.   (princ lst)
  24.   (princ)
  25. )
 楼主| 发表于 2015-5-3 20:03:16 | 显示全部楼层
鱼与熊掌 发表于 2015-5-3 19:32
不明白,不用关闭么?
GMT+8, 2025-5-22 04:35 , Processed in 0.168622 second(s), 27 queries , Gzip On.
